07-08-2015, 01:55 PM #1Junior Member
- May 2015
- old bridge nj
White- 2002 Pontiac Firebird WS6
2002 Firebird Trans Am / Install 7.5-7.625-4:10 gear install
I am having big problems setting up this gear set , the pinion is noisy and when accelerating , noisy also.
Richmond 4:10 Gear set for 3 carrier. The car has a BMR adjustable torque arm with the drive shaft loop. I tried several times to correct the noise problem but cant seem to get it right.
Has anyone tried this combination? Automatic 4L60E.
Any Suggestions.
Buick455
07-08-2015, 04:57 PM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
Who set up the rear when you changed the gears ? Did they use a new crush sleeve ? Did they set the backlash and run out correctly ? Did you have your driveshaft balanced ? What condition are your U-Joints in ? Does your rear have enough of the correct gear lube ? Is the housing set at the correct angle ? Try these ideas to see if anyone corrects the problem.
07-09-2015, 04:48 AM #3Junior Member
- May 2015
- old bridge nj
Buick455
I set the gears myself and have been doing for a long time, Instead of the crush sleeve I used the Spacer ,the u joints are new the gear lube is correct ,I went over the pinion angle but according to BMR I might be to shallow ,I am set at 1* neg and they recommend 2-3 *
I am going to go over the whole install , it only cost a couple of Qts of fluid and let you guy's know .
Thanks for the response,
Buick455
07-09-2015, 05:17 AM #4
2002 Trans Am PA Tail Lamp install problem
By Whamhammer in forum Firebird / WS6Replies: 3Last Post: 08-03-2012, 08:53 AM -
trans will not go into gear after clutch install
By ajonesz28 in forum Manual TransmissionReplies: 2Last Post: 12-03-2009, 02:07 PM -
CB or Amateur antenna install 2002 firebird
By Hooplah in forum Stereo and ElectronicsReplies: 21Last Post: 02-28-2009, 01:52 PM -
gear install
By badblazeSS in forum DrivetrainReplies: 1Last Post: 09-18-2008, 09:16 PM -
looking for 3.73 gear/install kit
By clg82 in forum Parts Wanted / TradeReplies: 0Last Post: 06-03-2007, 04:36 PM
