Results 1 to 11 of 11
10-12-2009, 04:47 PM #1
Getting out of gear with no clutch
Got tired of searching so don't flame on using the search, anywho, as stated I am able to get out of gear without the clutch, obviously its an m6, 99 ta with 88k on the odo, no mods to the drivetrain, is this normal by any means (prolly a dumb question lol), if not any ideas on how to fix it? I believe I have a hydrualic issue as my fluid was a low and when I topped it off the pedal felt much better. Thanks in advance
10-13-2009, 10:11 AM #2Member
- Mar 2007
- Gainesville, VA
You can get in or out of gear without the clutch. If your car is popping out of gear that's a problem.
10-13-2009, 06:42 PM #3
Its not popping out (thank god), just really able to get out of gear at about 1500 rpm, but I use the clutch to get it back in gear, a little scared to try and get it in without the clutch, thanks
10-13-2009, 07:10 PM #4Senior Member
- Apr 2008
- Madison, WI
Its normal to be able to pull out of gear without the clutch.
10-14-2009, 07:07 AM #5Army of 1
- Nov 2006
- Alachua, Fl
Ignition Orange/Black- 2008 G8 GT, 98 Z28 383
Totally normal
10-14-2009, 07:29 AM #6Member
- Sep 2009
- Nebraska
Pewter- 2002 Camaro SS
Technically a clutch is only needed to get the car moving from a dead stop, once you are rolling, you do not need to use the clutch at all, downshift, upshift, it is not need.
Use the clutch though, saves on transmission wear.
10-14-2009, 11:51 AM #7Member
- Nov 2008
- harrisburg pa.
black- 02 vette vert
maybe a little more help for you to understand this. if you are cruising with no load, neither de-celerating or accelerating, the transmission can be pulled out of gear very easily. the trick to putting it back in, or upshifting without the clutch is to match engine rpm to road speed for whatever gear you're trying to put it into. same with downshifting.
10-14-2009, 11:54 AM #8Member
- Mar 2007
- Gainesville, VA
10-14-2009, 12:05 PM #9
Yeah normal. I just learned the no clutch thing a little while back.. Well more like tried it.. But I don't like to do it just doesn't feel comfortable lol
2001 Camaro SS M6 SLP LMII, Lid
1987 iroc-z RIP 5.7 TPI Full exhaust, lingenfelter intake runners (gone but not forgotten)
1991 bmw 325i DD
10-18-2009, 01:33 PM #10
Thanks for all the info, and i do agree with ss on the not feeling comfortable part lol
10-18-2009, 08:03 PM #11Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
Total normality.
trans will not go into gear after clutch install
By ajonesz28 in forum Manual TransmissionReplies: 2Last Post: 12-03-2009, 02:07 PM -
dumped clutch in 1st gear...no start
By 1MileCrash in forum Manual TransmissionReplies: 11Last Post: 11-16-2007, 06:44 PM -
clutch locks up 1st gear in traffic while riding clutch
By Trixter in forum Manual TransmissionReplies: 9Last Post: 04-22-2007, 09:01 AM -
98 Z28 clutch fluid low, won't go in gear... HELP!
By Motrv8d Steve in forum General HelpReplies: 8Last Post: 04-06-2006, 12:58 PM -
Clutch or gear??
By JLSain in forum Manual TransmissionReplies: 3Last Post: 09-27-2005, 10:03 AM
