    Member JLSain's Avatar
    Kannapolis, NC
    2002 Camaro SS
    Question Clutch or gear??
    I ran my car at the dragstrip tonight. I ran 12 passes altogether... My only performance mod is a 4.11 GM Gear. On my last run, I stayed in 3rd and crossed the finish line at about 5500 rpms. On my way off the track, everytime I go to 3rd gear now, I have to force it and it grinds pretty good. It will go, but not without some grinding and force. What does that sound like? 3rd gear is the ONLY gear that is doing that. The other gears are fine, smooth shifting. It grinds EVERY time I shift it just about. The last run was also my best of the night. The only thing that I can think of that may have caused the grinding is that I stayed in 3rd till i redlined...
    Any help or diagnosis??
    Member Exotic Performance Plus's Avatar
    Aug 2003
    Columbia City, Indiana
    Hugger Orange
    1999 Z28
    You most likely either bent a shift fork, or bent one of the hollow and weak slider pins. It is very common for these transmissions to have these parts bend, causing the problems you described. Rodney at RPM Transmissions would be who I would recommend, he rebuilds all my customer's transmissions. Bob
    Check out our huge website at http://www.exoticperformanceplus.com
    Your Midwest Moser Specialist - We price match!
    Your Midwest ATI ProCharger Specialist - We only sell the best supercharger, the ATI ProCharger! We price match! 260 244-4808
    Kannapolis, NC
    2002 Camaro SS
    What about the synchronizer? It'll ease into 3rd if I shift normally from a stop.
    Crystal Lake IL
    2001 Camaro Z28 M6
    it could be a worn sychro ring...
  1. trans will not go into gear after clutch install
    By ajonesz28 in forum Manual Transmission
    Last Post: 12-03-2009, 02:07 PM
  2. Getting out of gear with no clutch
    By Red99TA in forum Manual Transmission
    Last Post: 10-18-2009, 08:03 PM
  3. dumped clutch in 1st gear...no start
    By 1MileCrash in forum Manual Transmission
    Last Post: 11-16-2007, 06:44 PM
  4. clutch locks up 1st gear in traffic while riding clutch
    By Trixter in forum Manual Transmission
    Last Post: 04-22-2007, 09:01 AM
  5. 98 Z28 clutch fluid low, won't go in gear... HELP!
    By Motrv8d Steve in forum General Help
    Last Post: 04-06-2006, 12:58 PM
