Results 1 to 3 of 3
    Redmond,Wa.
    2004 Pontiac GTO
    2004 stock GTO wheel alignment
    I ran over a parking lot curb while turning hard left. Now the steering wheel is off center to the left about a sixth of a turn. I can't see anything bent or damaged underneath. What could have moved? Maybe the rack shifted? Does anyone know what the toe-in is? I have stock 17 in. wheels and original tires, BFG 245/45-17 KDWS. 16000 miles on the car. I know this was a stupid thing to do,but it was dark and I didn't see the curb.
    Member Texas Jack's Avatar
    Central Texas
    Cyclone Grey
    2006 GTO M6
    Hey John, that was a hard hit, sorry. Sounds like you bent or moved something. I would look at the rack to see if it moved or a tie rod bent or stripped, also check to see if the tie rod end itself has been moved. I bet it you take your time you will find something moved, also check the steering box, have someone move the steering wheel while you watch everything. Sorry I don't know the toe in. Good luck.
    Member derbs's Avatar
    Jun 2006
    iowa
    IBM
    04 GTO
    Stock toe is .10 to .15
  1. Wheel Alignment Guide - DIY Alignment
    Last Post: 08-06-2009, 03:30 PM
  2. Question: Alignment without wheel lip
    By Wesman in forum Suspension and Handling
    Last Post: 05-31-2009, 06:04 PM
  3. Wheel alignment done right
    By Sarge in forum GTO
    Last Post: 04-08-2009, 06:01 AM
  4. Question: Wheel Alignment Done Yourself
    By GULLETT17 in forum Suspension and Handling
    Last Post: 06-11-2008, 07:43 AM
  5. wheel balance/alignment?
    By jrc1122 in forum Suspension and Handling
    Last Post: 10-04-2007, 05:22 PM
