Thread: wheel balance/alignment?
09-28-2007, 04:26 PM #1
So my car has recently been aligned (approx 3 months ago)
I bought new tires, and had my wheels balanced prior to installation - approx 1 month ago.
I have noticed almost immediately after putting on the new tires, that my car seems to "shake" at 55-70 mph. In fourth and fifth gear it is very noticeable.
my steering wheel shakes a bit, but my passenger seat (with no one in it) shows the obvious problem, It literally shakes enough to see it moving?
What does that sound like?
Any help would be greatly appreciated.
PS I am getting bad vibes about this. LOL
2009 Pontiac G8 GT
Liquid Red
09-28-2007, 05:47 PM #2
Wheel balance problem?
'01 BMW 330ci: Race it in a modified class in BMW CCA Club Racing and NASA endurance races.
'04 Lincoln LS V8 Sport: Stock.
'04 Mustang Cobra coupe (white/gray): Modified.
10-03-2007, 03:58 PM #3
never been 100% on any post but, i i am in this one, that is tire balancing. i had the same problem and drove like it for a month. my pass seat was moving back and forth crazyyyy. then took it up to the shop and the right rear was 3.75 OZ weight off . after that $8 fix. its a smooth ride, and my cheeks on my face arnt giggleing any more.
have them recheck the balancing since it wasnt doing it before. i wieght could of broke off or worse case secnario it could be a bent rim but dought it
10-03-2007, 04:18 PM #4
10-03-2007, 04:23 PM #5
trust me, once you said your pass seats were shaking crazy i knew what it was. i only have 35 K on car soo i was really worried since it soo new. but that was the best $8 fix i ever done
good luck, and post soon as
10-03-2007, 07:05 PM #62000 Arctic White trans am, ws6 hood, ws6 air box, slp lid, slp smooth bellows, slp loudmouth exhaust,shift kit, rebuilt trans, LS6 intake, 3.73 gears, Shaner S3 p/p throttle body, and a tune . SFC. C6 ZO6 rims 18" in back 17" in front. Drilled and slotted rotors.
10-04-2007, 05:04 AM #7
Any Pulling Issue Is A Wheel Alignment Issue....any Vibration Or Shaking At Highway Speeds Is Usually A Wheel Balance Issue. Take It To A Dealership For Either Because Most After Market Shops Will Balance Wheels But Not Balance Out Load Force. Without Knowing Load Force, You Will Never Know If You Just Flat Out Have A Bad Tire. Knowledge Is Power.
10-04-2007, 03:33 PM #8Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
10-04-2007, 03:37 PM #9
you could possibly have a tire starting to seperate. have they tried moving the tires front to back or side to side to see if the pull changes? if the pull doesn't change after swapping tires around, have the alignment checked.
incorrect. there are other inluences to cause a car to pull. tires, brakes, worn parts, or power steering. i run an alignment/suspension shop.
10-04-2007, 05:08 PM #10
Originally Posted by mrr23
my apologies, i should have said, "usually means" obviously, as you probably know, without getting more information or physically seeing the vehicle its pretty difficult to determine.Last edited by mrr23; 10-04-2007 at 05:14 PM. Reason: fixed quote
2018 Tahoe - Silver - OEM
10-04-2007, 05:14 PM #11
that's better.
10-04-2007, 05:22 PM #12
Wheel Balance
By pajeff02 in forum Drag RacingReplies: 39Last Post: 08-18-2010, 08:53 PM -
Wheel Alignment Guide - DIY Alignment
By Ed Blown Vert in forum Almost Anything GoesReplies: 5Last Post: 08-06-2009, 03:30 PM -
Question: Alignment without wheel lip
By Wesman in forum Suspension and HandlingReplies: 13Last Post: 05-31-2009, 06:04 PM -
Wheel alignment done right
By Sarge in forum GTOReplies: 19Last Post: 04-08-2009, 06:01 AM -
Question: Wheel Alignment Done Yourself
By GULLETT17 in forum Suspension and HandlingReplies: 6Last Post: 06-11-2008, 07:43 AM
