Results 1 to 20 of 20
    Retired Outlaw Sum Bitch
    Wheel alignment done right
    Shit.....finally got all the time I needed on the rack.....
    Guys....-8.1 degrees on the drivers side and -8.3 on the passenger (caster) is the fucking balls.....finally.....this thing tracks like its on rails.....so after almost five years I got this alignment thing down....
    Member GTO1_OHIO's Avatar
    Melbourne Beach, FL
    Phantom Black Metallic
    2004 GTO
    You ever get your cradles aligned? ...drum roll
    Nope....
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    I heard ther was a lot of issues with this had mine checkd,they said it was all good maybe them frame ties have something ti do with that...?
    No GM/Pedders specs all call for -7's ish.....go -8's.....even my steering wheel is now smooth as hell at all speeds...
    Indianapolis
    2000 WS6 6spd Hooker LT
    Now are stating the caster is supposed to be negative 8 degrees caster? Should be positive, correct?
    Moving the wheels back...
    Indianapolis
    Alright, Alfalfa, by moving the wheels back, you must be stating the relationship between the upper pivot point and the lower, by pushing the lower ball joint forward for more positive caster. Or maybe you could explain the caster reading better? Or maybe when I get back to the shop Monday I can see what the factory specs are, and what your good results are. As you know, once you start modding cars the factory specs aren't the best.
    LOL....by adjusting the spacers in the radius rod bushing....front/back 8mm/4mm/2mm increments we got the 8.1/8.3 and finally got this pig to track the way she should....factory specs are like a full degree less in the 7's......
    We are a tad over a half degree off Pedders more aggressive specs...
    http://www.peddersusa.com/images/PDF...nt%20Specs.pdf
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yeah Sarge -8.6 and 8.8 feel great on the space saver spares on the big end @ 120+ too.
    Noticeable positive difference....
    Melbourne Beach, FL
    2004 GTO
    Back Street Performance, my tuner and Pedders dealer ... don't have my car set up using the vanilla Pedders specs either. ...and I did have a front and rear cradle alignment done.
    Cincinnati
    Torrid Red
    2004 GTO
    Quote Originally Posted by GTO1_OHIO View Post
    What did Rich charge for the service? How you been? Going to Dayton in July?
    Indianapolis
    Now that makes sense. You are increasing the positive caster. Usually that gives more stable handling, depending on front suspension design. I guess I didn't want anyone confused by your first post, if you look at it one way it looks like you could be saying the caster spec is -8.2 degrees, and that would be hard to get since the stock caster spec is like +7.2.
    Yeah I see what your saying......
    Melbourne Beach, FL
    2004 GTO
    Quote Originally Posted by cquist View Post
    Mine was bundled in wih some other things plus my car was the first Pedders car that he did so I got a major discount for the install. Rich charges way less then the other Pedders dealers for labor though since he's a smaller operation and dosen't carry the same overhead costs.
    I just posted over on lsxgto that I am ... have to if I'm going to win the drag race Stock Bracket.
    Member PatrizioD's Avatar
    The Anus of America; RI
    Nero
    2006 gto
    Bringin this back hoping Sarge sees it somehow... will these caster angles help with strut rub? And what would be ideal camber? The Pedder's pdf that im lookin at says
    Left -0.25 Right -0.3 Camber
    Left & Right 7.5 Caster
    Also, if my factory bushings are still good, will these specs work with 'em? Dont have the cash to swap out the bushings/strut mounts yet unless they're shot.
    Indianapolis
    Caster should not affect strut rub. Camber would, if it is too far negative or if some suspension piece is worn out. Too far negative would be more than -.5 degrees.
    King of Lurkers ne0fiend's Avatar
    Clearwater, Florida, United St
    04M6 GTO
    Though I respect setting an alignment to specs you, the driver feels most comfortable with, I think it's important to note that a bad or out-of-tolerance alignment cannot cause steering wheel shake.
    In many cases when we set out to aliviate a shake or shimmy in our wheel by adjusting our alignment, we offten make it worse.
    It's also important to note that extreme or otherwise beyond-thresh hold tolerances can, in fact make the shake go away - the root of the problem is still there.
    I find that when I'm coming out of a straight away into a turn - depending on the angle I start my drift - I can feel a shake in my wheel from 11 o'c to 1 o'c.
    Because I use posative camber in the rear and negative camber in the front, It's hard to say if it's the measurements or just tire balance.
    Anyway, the ability to set your own alignment is a wonderful weapon in your racing bag.
    Alignment is, at least in my opinion, the most over-looked element in over all tuning.
    Here's an easy key to use as reference when setting Cs, Cm and Toe -
    Caster: The measurement of forward/backward position of the wheel.
    Camber: The measurement of latteral tilt, ascertained from top, to bottom of the wheel.
    Toe: The measurement of Inward/Outward angle of the tire, ascertained from front to back of the visable face of the wheel.
    Normal Caster: O--O
    Caster set with an extreme right side measurment: O--o (note the right tire is behind the left somewhat)
    Normal Camber: ||--||
    Camber set for extreme cornering: //--\\ (note the outward angle of the tires)
    Toe is self explanitory.
  1. Question: 2004 stock GTO wheel alignment
    By John Carlson in forum GTO
    Last Post: 11-20-2009, 05:15 PM
  2. Wheel Alignment Guide - DIY Alignment
    Last Post: 08-06-2009, 03:30 PM
  3. Question: Alignment without wheel lip
    By Wesman in forum Suspension and Handling
    Last Post: 05-31-2009, 06:04 PM
  4. Question: Wheel Alignment Done Yourself
    By GULLETT17 in forum Suspension and Handling
    Last Post: 06-11-2008, 07:43 AM
  5. wheel balance/alignment?
    By jrc1122 in forum Suspension and Handling
    Last Post: 10-04-2007, 05:22 PM
