Results 1 to 14 of 14
Thread: Alignment without wheel lip
05-25-2009, 08:39 PM #1
I just got a new wheel and tire setup on my car, and I was going to get a wheel alignment, since I haven't ever had one done since I've owned the car.
The problem is my wheels don't have any lip on the face for the satellites to lock into.
Anyone know of an alignment rack that doesn't require a wheel lip and who would have it??1998 Trans Am WS6 SGM
Lid, Pro 5.0, WS6 Short Stick, LS7 Clutch, TB Bypass, Detroit TrueTrac, Poly Mounts, Bilstein Shocks, LS6 Intake, SFCs, CTS-V Brake Upgrade, STB, Nitto 555's. SS Longtube Headers and True Duals w/ H pipe and Magnaflows. Tuned by Harris Speed Works. 341.4WHP/346.1 lb/ft.
05-27-2009, 05:13 PM #2
um they should have the finger adapters to hook on the outside of the wheel lip instead of the inside. nothing new. been around for a decade or so. i have them for both of my alignment machines.
05-27-2009, 08:02 PM #3
Interesting, the guy I talked to didn't have those. The other problem is the tires have a rimguard, so I don't think even that would work.
I have a set of 16" salad shooters that I could put on just for the alignment which have a lip...would using those throw off the alignment once I put the 18"s back on??
05-27-2009, 08:05 PM #4
the fingers will work so long as they can push them between the rim guard and rim. done it a good 100 times myself. they make different angle fingers.
you can put the 16s on and align it that way.
05-27-2009, 08:06 PM #5
05-31-2009, 03:53 PM #6
05-31-2009, 04:54 PM #7
Apparently the GM dealer near me has all the alignment equipment to do wheels without lips. My friend works for a Honda dealer, and he said they send all their newer cars without wheel lips cars to this GM dealer to get alignments.
My car isn't lowered, but either way the dealer should have all the special tools for camber/caster if any are needed. I'll call them in the morning and get a price.
05-31-2009, 05:00 PM #8
what special tool would that be? maybe the same one if it isn't lowered? not that you really need the tool. just makes it a little easier to do.
here's a pic of the alignment tool. this is not a have to have tool, but i own two of these cars. this is the position to adjust camber
here's the position to adjust caster
05-31-2009, 05:07 PM #9
05-31-2009, 05:10 PM #10
05-31-2009, 05:15 PM #11
yeah thats it. and sad to say that most alignment shops would prob only do the toe anyhow. and youre right, cant say for sure it wouldnt need adjusted, but doubt it would be out enough to cause any wear. and i NEEDED the tool. had to borrow it from a local gm dealer. my car was lowered and there was no way to pull the camber in enough. took 2 min with it.
05-31-2009, 05:17 PM #12
yes the tool makes it much easier to do the work.
05-31-2009, 05:29 PM #13
05-31-2009, 06:04 PM #14
toe is the primary tire wear angle with camber being second.
Question: 2004 stock GTO wheel alignment
By John Carlson in forum GTOReplies: 2Last Post: 11-20-2009, 05:15 PM -
Wheel Alignment Guide - DIY Alignment
By Ed Blown Vert in forum Almost Anything GoesReplies: 5Last Post: 08-06-2009, 03:30 PM -
Wheel alignment done right
By Sarge in forum GTOReplies: 19Last Post: 04-08-2009, 06:01 AM -
Question: Wheel Alignment Done Yourself
By GULLETT17 in forum Suspension and HandlingReplies: 6Last Post: 06-11-2008, 07:43 AM -
wheel balance/alignment?
By jrc1122 in forum Suspension and HandlingReplies: 11Last Post: 10-04-2007, 05:22 PM
