Results 1 to 2 of 2
    2002 WS6 Trans Am
    Transmission making loud clanking noise
    I have a 2002 WS6 T/A with a 6-speed tranny I had rebuilt by "sixspeedsinc", of course they are out of business now. It is making a loud metal on metal clanking noise when the car is not moving, parking brake on, in neutral gear, but only after letting off the gas. So, going from say 2000 rpms back down to idle. It does not make the noise at idle or while you are giving it gas. Also, the transmission has been leaking fluid from where the tail shaft meets the main section. Could low fluid be the cause?
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Well, the leak is fairly common, and easy to change. The output shaft seal is around 10 bucks. The noise could be many things, get the car up nice and level or go have the oil level checked. Usually that seal will just seap and not actually leak, so your probably fine on oil level.
  1. rear end loud noise
    By ice97ta in forum GTO
    Last Post: 10-28-2012, 09:06 AM
  2. loud screeching noise
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 06-16-2012, 06:29 AM
  3. Rear Metal Clanking Noise
    By Rikki_SeVeN in forum Suspension and Handling
    Last Post: 10-28-2008, 02:47 AM
  4. clanking noise when going from 1st to 2nd
    By anchlo in forum Drivetrain
    Last Post: 09-20-2008, 01:21 PM
  5. Loud Squeeking Noise!
    By justinlandis in forum Suspension and Handling
    Last Post: 10-04-2006, 05:32 PM
