Results 1 to 14 of 14
    Park City, Ut
    midnight blue
    2000
    Thumbs down my headlight is making noise
    Today, I drove my car for the first time in a week. I notice that when i turned off my car, my headlights were floping up und down. There was a loud rattle. Does that mean that the headlight motor is gooing out?
    Jul 2009
    Lawrenceville GA
    1999 Trans Am
    yup the gears stripped
    Park City, Ut
    midnight blue
    2000
    do i need to buy the complete mototr or just the gear.
    Kansas
    1999 T/A WS.6
    Quote Originally Posted by wickedbeast View Post
    Gear most likely, however, there's a chance the snake gear inside is stripped also.
    Park City, Ut
    midnight blue
    2000
    that sucks. any ideas where i can find it
    My ex bf is a stalker smartinz26's Avatar
    Jan 2008
    Machesney Park, IL
    99 Firehawk
    http://www.rodneydickman.com/retail_new.html
    go to electrical scroll down.
    Kansas
    1999 T/A WS.6
    Got mine from autozone. Was like six bucks.
    Quote Originally Posted by MistrCreazil View Post
    don't see how this is possible.....the gear is nylon and the driver is metal? Never heard of nylon stripping metal.
    Here's a ton of info on the headlight issue along with an order sheet for brass gears.
    http://www.bfranker.badz28.com/headlightfix/#Ordering
    Kansas
    1999 T/A WS.6
    It happened to me. After buying another plastic gear it still grinded but the plastic gear was nearly unscathed.
    Member TA98's Avatar
    Mar 2009
    Maryland
    you can filp the gear 180 degrees. the motor only uses half the gear to lift the headlight up
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    Just replace the gears with the brass ones. It's a common fix on our cars. The motor itself, when it goes out you'll be winking
    Park City, Ut
    midnight blue
    2000
    thanx for all the info. im gonna try the spinning the gear 180 first if ti doesnt work im donna get a brass one.
    Member herculesrider1's Avatar
    TX
    '00 TransAm RamAir WS6 M6
    The Rodney Dickman kit comes with the brass gear, gear lube, epoxy, and a metal reinforcement piece that holds down and secures the cover from coming off, along with good instructions. In my decision making process, I considered the metal reinforcement piece the scale tipper given the price is comparable. I would recommend the Rodney Dickman kit hands down because the epoxy in and of itself is prone to coming apart and actually has come apart on my car with a kit that was installed prior to my purchase. The metal reinforcement pieces, to me, will keep me from having to re-do this again.
    Park City, Ut
    midnight blue
    2000
    thanx that is really helpful
  1. LCA's making noise
    By 1998 T/A in forum Suspension and Handling
    Last Post: 07-27-2015, 11:54 AM
  2. Help: Is this my cat making all this noise?
    By psycho_puppies in forum General Help
    Last Post: 05-30-2012, 02:26 PM
  3. Help: LS1 making a bad noise!
    By AdamLS1_08 in forum Firebird / WS6
    Last Post: 07-17-2008, 07:19 PM
  4. Brass gear in headlight... still making grinding noise
    By JehalinTA in forum General Help
    Last Post: 07-19-2007, 06:24 AM
  5. making a noise?????????
    By hawk1125 in forum Suspension and Handling
    Last Post: 06-19-2007, 01:52 PM
