Results 1 to 20 of 20
    Junior Member psycho_puppies's Avatar
    Jul 2009
    New Mexico
    2002 TA
    Is this my cat making all this noise?
    link doesn't work
    Nov 2009
    North Carolina
    2001 Camaro Z28
    ^^ no link. but if its a rattle that changes with engine RPM its very likely, I had some aftermarket cats that kept shaking pieces loose and they would make some pretty loud rattles
    Jul 2009
    New Mexico
    2002 TA
    This should work
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Thumbs down
    I am not an expert by any means on these vehicles, it sounds like a rod knock to me.
    SteveC
    Quote Originally Posted by SteveC View Post
    SteveC
    I agree....sounds way more serious than a cat. Mic's don't always transfer the sound correctly but that sounds pretty bad IMO.
    Member Guerrillakilla13's Avatar
    Feb 2011
    Arizona
    2002 Trans Am WS6
    I can't get the video to work on my mobile, it happens when your car is on in general? How does it sound when you drive?
    2014 Camaro: Check. 2SS: Check. 1LE: Check. 6 Speed manual? CHECK
    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    Sounds to consistent to be a cat. I had a cat blow out on my SS and it was a more inconsistent rattle
    Jul 2009
    New Mexico
    2002 TA
    The car drives fine. I have an appointment with the dealership on Monday because the Cats in my car are still under warrenty. Also, when I bang on the right cat with a rubber mallet it replicates the noise. The car only had 27k on the clock.
    Feb 2011
    Arizona
    2002 Trans Am WS6
    wow and I honestly didn't think catalytic converters could go bad..thanks for proving they can GM.
    OP keep us updated
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by Guerrillakilla13 View Post
    OP keep us updated
    Problems with GM cat's are common..
    OP..
    It sounds exactly how my 01 Camaro sounded when the cat shit the bed..
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by Guerrillakilla13:2777233
    OP keep us updated
    Typically an engine not running correctly is what causes them to fail prematurely.
    Jul 2009
    New Mexico
    2002 TA
    I will let you all know when they tell me. I hope to know by tomorrow afternoon.
    OP keep us updated
    Feb 2011
    Arizona
    2002 Trans Am WS6
    I would hope that isn't the case with our cars... LS1's are beast and reliable
    Pittsburgh
    2008 Hummer H3
    Mine had ~80k and nothing wrong either.. GM cats = junk.
    Jul 2009
    New Mexico
    2002 TA
    The dealership just called. Both cats are bad.
    Feb 2011
    Arizona
    2002 Trans Am WS6
    Both of them?? Wow..at least they're covering the cost
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by psycho_puppies View Post
    Yup the sound your car and mine were making can be confusing as it sounded like the engine is/was coming apart on mine aswell.
    Cut my old one out and sure enough the grid/mesh inside was broken in two.
    Too bad I had to cut up a perfectly good exhaust to find out.
    Just was a general statement. There is/was a warranty claim issued for our cars about premature failure for the catalytic converters.
    Nov 2009
    North Carolina
    2001 Camaro Z28
    ^^ yupp there was a recall on the cats had mine replaced for free the driver side one went with only 22k miles on it
  1. LCA's making noise
    By 1998 T/A in forum Suspension and Handling
    Last Post: 07-27-2015, 11:54 AM
  2. Question: my headlight is making noise
    By wickedbeast in forum Firebird / WS6
    Last Post: 11-03-2009, 12:30 PM
  3. Rear Making Noise
    By tatertot91 in forum Manual Transmission
    Last Post: 02-09-2009, 05:42 PM
  4. Help: LS1 making a bad noise!
    By AdamLS1_08 in forum Firebird / WS6
    Last Post: 07-17-2008, 07:19 PM
  5. making a noise?????????
    By hawk1125 in forum Suspension and Handling
    Last Post: 06-19-2007, 01:52 PM
