    houston
    Navy Blue
    ls1 trans am
    Brass gear in headlight... still making grinding noise
    Hello,
    about a year ago I replaced the driver side headlight motor gear with a brass one because the nylon gear had stripped and was causing a grinding sound. everything was working fine until a few days ago when the headlight started to make an identical sound. My question is has any of you experienced this problem because I am not sure what could cause this. Has any of you had the worm gear strip in the same manner. If so what is the solution. I have not checked the tabs yet to see if they have come loose. Thank you for you guys input.
    Member Transam388's Avatar
    Cypress, TX
    98 Trans AM
    I had this and all that had happened was the glue after I put the gear in had worn down so the cover plate was loose. Once I re epoxied it and made sure it had enough to hold the sound was gone. Good luck!
    98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
    houston
    Navy Blue
    ls1 trans am
    yea I took it apart yesterday and the expoxy had come off as well. From what I hear with the amount of pressure the motor puts on that plastic piece and the way glue sticks to the plastic, the expoxy alone is not enough. I saw on some guys website that they sell a bracket that you can place over the screws however with shipping it is $10 which is too much for a T shapped washer. I have heard of guys putting screws in to hold the plastic lid on or I might make myself a bracket. I can definately see why they got rid of the flip up lights in the new corvette. First of all a plastic gear? give me a break
    Tampa, Fl.
    You need to get the gears with the reenforment plate on it. It makes sure that if it ever comes off again, it keeps this cover in place. I went through this before and bought the plate. No more problems.
    Junior Member tatom's Avatar
    TX
    SOM
    2002 WS6
    i had the same thing happen with the epoxy not holding..i went to home depot and bought a piece of 16 gauge sheet metal...made a cardboard template of the holes...drilled them...painted the metal (so not to rust)...cleaned the plastic, re-epoxied it back together and put it back together with the bracket....no problems ...when i bought the brass gear i got 2 of em .... so when i made the bracket i made two at the same time ...i knew the other gear would go and it did 2 days ago...i did not know about the bracket when i bought my gears....anyone buying brass gears should buy the gears that come with the bracket included
  1. For Sale: Rodney Dickman 93-02 Firebird headlight brass gear kit
    By JayTA98 in forum Parts For Sale / Trade
    Last Post: 11-14-2014, 02:17 PM
  2. Help: Headlight Gear Grinding
    By Ant71130 in forum Firebird / WS6
    Last Post: 05-21-2011, 07:56 AM
  3. Question: my headlight is making noise
    By wickedbeast in forum Firebird / WS6
    Last Post: 11-03-2009, 12:30 PM
  4. Brass Headlight Gear
    By TransAmFanatic in forum Firebird / WS6
    Last Post: 04-25-2008, 11:47 AM
  5. Brass headlight gears
    By GSXING in forum Firebird / WS6
    Last Post: 12-01-2006, 07:28 AM
