09-24-2009, 10:12 AM #1Junior Member
- Jun 2006
- Pocatello, ID
Black- 2000 SS Camaro
Rear end fluid change. Limited slip additive ?'s
I did a rear end fluid change on my 2000 SS which now has 58K on it. I hadn't done one in about 35K miles and the fluid looked just fine. I put in what I always put in mobile 1 75/90. used a new gasket yadda yadda yadda but my real question is GM additive 89021958 is what was sold to me at the dealership when I asked for limited slip additive. This crap was like $19! and it looked different then what i used last time which I think was part # 1052358. The guy at the counter said that this was the new part number and it replaced the old one. Anways I dumped it all in (I think 4 ounces) and now I am reading that is a concentrate and you are only supposed to use like 1 ounce or something like that and its for a GTO or something. I have not drove it more than maybe 2 miles and everything sounded ok but whats the story here. Did I screw up and use the wrong stuff? Is the guy from the GM dealership full of crap? I am going to have problems? Doing this kind of work is a PITA cause I live in a apartment and I do not want to change out new fluid but if I need to I will. This did not look like the usual whale sperm lol that I had been getting from GM but instead it looks like a green dye of some kind and it seems pretty runny and not thick. Any thoughts?
Thanks,
09-24-2009, 12:21 PM #2
It is very expensive stuff buying it from the dealership. Your supposed to put all of it in. Chinazone has it cheaper. Your fine
09-24-2009, 04:14 PM #3
As far as I know, the 99 and up cars have a Torsen differential which doesn't require an additive, but it doesn't hurt to add it.
This is straight from install university:
You need to fill the rear differential with the fluid. The housing will take approximately (two) 2 quarts of fluid. As we stated at the top of the install document we used the GM additive but there is no need to do this in a Torsen unit.
09-24-2009, 07:39 PM #4
09-27-2009, 05:09 AM #5
Jeg's has its version of the GM additive for alot less.
SteveC
09-27-2009, 06:46 AM #6Member
- Nov 2008
- harrisburg pa.
black- 02 vette vert
GM part#1052358-$7.99-WS6 Store
09-27-2009, 08:23 AM #7
Yep, if you have the Torsen, no need for the additive.
09 Vulcan 900 custom.
2007 Subaru Legacy 2.5i
1998 Z/28 Hardtop A4 | Y2K wheels | SLP Lid | Magnaflow catback |cutout | Hotchkis LCA'S/PHB | BMR TA and D/S Loop| Tuned by Frost....300rwhp/308rwtq
97 Cobra- bolt ons | full exhaust| 4.30's| suspension | SCT tune- sold!
Question: Swapping open rear end to limited slip disc brake
By Tealcamaro in forum V6Replies: 1Last Post: 09-07-2012, 06:10 PM -
gm limited slip additive
By godless-phoenix in forum Firebird / WS6Replies: 13Last Post: 12-05-2010, 04:53 AM -
Did a rear end fluid change...
By RPO_WU8 in forum DrivetrainReplies: 6Last Post: 09-26-2009, 12:06 PM -
By whiteLS1TA in forum DrivetrainReplies: 15Last Post: 01-18-2008, 02:14 PM -
GM Limited Slip Additive...
By kevinfromwebb in forum DrivetrainReplies: 7Last Post: 04-02-2006, 02:35 PM
