Results 1 to 14 of 14
Thread: gm limited slip additive
12-02-2010, 01:02 PM #1Member
- Jan 2010
- culver city, Ca.
Blackened fire chicken- 2000 Pontiac Trans Am WS6
hey-lo my friends, i was wondering if the gm limited slip additive would be ok to add after i put the diff. fluid in already...i forgot to add it when i put in new diff. fluid, witch was a few months ago, and it whines at lower speeds, so i was just going to go ahead and add it, if thats ok...dont want to mess anything up of course
12-02-2010, 01:33 PM #2Senior Member
- Nov 2006
- Indianapolis
Won't hurt. But probably won't help a whine either. The only problem I see is getting it in, since your already full. Siphon some out, maybe, but no too much. The additive is there mostly to prevent the limited slip clutches from making noise in tight corners.
12-02-2010, 02:01 PM #3Member
- Jan 2010
- culver city, Ca.
ahh i see ok...so, what do u think would help the whining, its bad when im in reverse, but i can hear it at lower speeds... i had my diff. repaired a couple years ago and i have a mac rear end gurdle if any of this info helps
12-02-2010, 02:26 PM #4Electrical Engineer
- Jul 2009
- North of the Motorcity
You need to check the fluid you added into it. If it already contains additive, DON'T add anymore additive.
I know most Lucas products have it, but double check none the less.
12-02-2010, 02:49 PM #5
12-02-2010, 07:04 PM #6
Clutch type or torsen posi? Even with torsen they recommend the limited slip additive -- had to look it up for another member not too long ago.
12-02-2010, 07:16 PM #7Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
i put some on mine twice... it didnt work..
still whines starts at 35mph and stops at 80..
why? i dont know00 ss blk m6 " STOCK" strano springs, slp bilstein shocks, adj LCA, adj panhard bar, relocation brackets, 2 point SFCs welded,OEM zo6 rims black, magnaflow exhaust, CME exhaust,E/cutout, slp grille, custom front plate mount, HIDs, whistler mod, side moldings delete, slp air lid, ported and polished TB, strut tower brace, 3.73s gears, and some other parts to list!
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
12-02-2010, 08:44 PM #8
12-03-2010, 02:25 AM #9Senior Member
- Nov 2006
- Indianapolis
Here's how to tell the difference between a clutch type and a torsen equuipped diff, if you can get both rear wheels off the ground at the same time:
Spin one of them forward. If the other side goes forward with it, you have a cltuch type.
If the other side doesn't move, or spins in reverse roatation, then either you clutch type limited slip is completely worn out or your car has the torsen style. This always jacked people up at my shop, they said "You car doesn't even have a posi???" Tryed to explain that a torsen works differently, but they still had a hard time believing me.
And, again, the additive most likely won't stop any kind of whine, but it won't hurt to try.
12-03-2010, 03:01 AM #10
From what I have read on here, '99 was the transition year to the torsen differential. Here's the quip about additive: http://www.torsen.com/general/genera...modifier added
12-03-2010, 07:24 AM #11Member
- Jan 2010
- culver city, Ca.
i just assumed it was clutch type, cause i had no idea,haha...but ill take your word for it
so i have the torsen style...from burn-outs, i can tell when im going straight, both tires will make marks, but if im turning right lets say, and burning out, i only see one tire mark...im going to adjust my rear lower control arms this weekend, so when i have the car up ill spin the tires just for piece of mind
12-04-2010, 07:22 PM #12
FWIW, some diffs don't like synthetic oil, mine is one (auburn) and I run two bottles of gm additive in mine with dino oil, runs quiet. Also, I have heard of people running ford posi additive too.
Regards,
Todd
#cajunhotrodder on instagram
12-04-2010, 08:57 PM #13Member
- Jan 2010
- culver city, Ca.
i put in the additive today, let you guys know in a day or 2 what happens...also i turned the wheel when i had it jacked up, and the other wheel does turn the opposite way. so i do have a torsen
i also noticed some "play" in the axle. when i was turning the wheel forward, and then went to turn it backwards, the axle would take second to "lock up" it seemed like, dont know if thats good or bad...
12-05-2010, 04:53 AM #14
The play you described sounds normal to me.
Rear end fluid change. Limited slip additive ?'s
By RPO_WU8 in forum General HelpReplies: 6Last Post: 09-27-2009, 08:23 AM -
Limited Slip Not Working?
By gearhead1 in forum DrivetrainReplies: 11Last Post: 03-05-2007, 04:21 PM -
GM Limited Slip Additive...
By kevinfromwebb in forum DrivetrainReplies: 7Last Post: 04-02-2006, 02:35 PM -
2000 A4 WS6 -- How do I know if I still have limited-slip??
By ScrapMaker in forum DrivetrainReplies: 2Last Post: 02-06-2006, 09:54 AM -
limited slip question
By rick-z28 in forum DrivetrainReplies: 3Last Post: 01-30-2006, 04:27 AM
