Thread: Limited Slip Not Working?
02-21-2007, 01:02 PM #1Junior Member
- Mar 2006
- Burgettstown, PA
Black- 2002 Trans Am
I have an 02 WS6. Although I don't drive it during the winter, I wanted to move it out of the driveway to remove the snow from around it. I got stuck in the snow, and only the passenger side wheel spun and the driver side didn't do anything. Does anybody know why this could be?
02-21-2007, 03:30 PM #2
You have a torsen diff. It will do that.
02-22-2007, 04:11 AM #3Member
- Nov 2006
- Earth
If you apply slight braking the torque sensing will engage the other axle. This is the draw back of the Zexel. Unlike the clutch type, the geared interlocking of the axles must have some resistance on both wheels to engage. The Zexel is a performance differential that works very well on pavement but as you found out, when there is near zero resistance on either side, you are as dead in the snow as if you had an open differential.
03-04-2007, 07:22 PM #4
03-05-2007, 10:57 AM #5Impounded
- Feb 2007
- Pa
Red- 99 TA
if its the torsen carrier its broken,i had the same problem 3 years ago.Dealer replaced the carrier,the gear shafts inside the torsen unit break causing one wheel only to drive.another way to test the torsen is in the rain,if its broken it will one wheel in the rain also.since mine was replaced it turns both wheels in the snow and rain.don't let anyone bs you about it.
03-05-2007, 11:11 AM #6
How is it GM's fault?? The Torsen diff is made by Zexel, and its designed to work that way. If one wheel has no traction, the unit can't function as a limited slip. One wheel must have at least some traction in order for power to be transferred to the other wheel. Plenty of cars have Torsen style differentials, its not only F-Bodies.
03-05-2007, 11:14 AM #7Impounded
- Feb 2007
- Pa
Red- 99 TA
its broken! the stock carrier breaks very easily.
03-05-2007, 12:09 PM #8
03-05-2007, 03:36 PM #9
03-05-2007, 04:12 PM #10Impounded
- Feb 2007
- Pa
Red- 99 TA
03-05-2007, 04:14 PM #11
03-05-2007, 04:21 PM #12
gm limited slip additive
By godless-phoenix in forum Firebird / WS6Replies: 13Last Post: 12-05-2010, 04:53 AM -
Eaton Limited Slip
By robert 98 in forum DrivetrainReplies: 2Last Post: 03-09-2008, 01:06 PM -
99 Z28 Which type of Limited Slip
By thende2617 in forum DrivetrainReplies: 4Last Post: 10-25-2006, 10:21 AM -
2000 A4 WS6 -- How do I know if I still have limited-slip??
By ScrapMaker in forum DrivetrainReplies: 2Last Post: 02-06-2006, 09:54 AM -
limited slip question
By rick-z28 in forum DrivetrainReplies: 3Last Post: 01-30-2006, 04:27 AM
