10-23-2006, 05:03 PM #1Junior Member
- Oct 2006
- US
Silver- 99 Z-28
99 Z28 Which type of Limited Slip
As a new owner of a 99 Z28 M6 with a 3:42 gear, what type is it?
The older Clutch type or the new Torsen, reason is, do I need to add the GM limited slip (I have it), also have Mobil 1.
slight noise from rear that increases in pitch as speed increases, but seems solid. I do notice it changes (lowers frequency) when I pull the ebrake handle a bit (Might change load on wheel bearing or ebrake issue)???
Thanks new to this year Camaro.
Tim
10-23-2006, 07:55 PM #2
You've got a Torsen diff. No need for the additive but I always threw it in there anyway. I'd use a dino 80-90 gear oil.
10-24-2006, 03:05 PM #3Senior Member
- Jul 2005
- Jacksonville, FL
I'd use it, bet your owners manual says to with a complete drain and refill for LSD diffs - mine does. Some gear oils say it's included in their product or not needed, but I use it anyway.
10-25-2006, 07:17 AM #4Junior Member
- Oct 2006
- US
Silver- 99 Z-28
Thanks for the input, also I bought the gasket, is it installed dry or with sealant?
10-25-2006, 10:21 AM #5Senior Member
- Jul 2005
- Jacksonville, FL
Good question, when I put my TA Performance cover on I just used RTV only and it's been fine. Just looked it up in my '01 helms and it says "Install a new rear axle housing cover gasket. Install the rear axle housing cover. Install the park brake cable guides...Tighten the rear axle housing cover bolts in a cross pattern to 22 lb ft." No mention of any sealant required, so I guess dry is fine.
gm limited slip additive
By godless-phoenix in forum Firebird / WS6Replies: 13Last Post: 12-05-2010, 04:53 AM -
Limited Slip Not Working?
By gearhead1 in forum DrivetrainReplies: 11Last Post: 03-05-2007, 04:21 PM -
GM Limited Slip Additive...
By kevinfromwebb in forum DrivetrainReplies: 7Last Post: 04-02-2006, 02:35 PM -
2000 A4 WS6 -- How do I know if I still have limited-slip??
By ScrapMaker in forum DrivetrainReplies: 2Last Post: 02-06-2006, 09:54 AM -
limited slip question
By rick-z28 in forum DrivetrainReplies: 3Last Post: 01-30-2006, 04:27 AM
