Results 1 to 3 of 3
Thread: wont start
    Jul 2009
    s.a. tx
    navy blue met
    1998 Trans Am convertible
    wont start
    Wife ran my car outta gas now it wont start even after adding four gallon of fuel. Has this happened to anyone? Any feedback would be helpful>
    Memphis,TN
    2001 Z28 Camaro
    May have burned up the fuel pump when you ran out of gas. also check your fuse for the fuel pump as well
    Quote Originally Posted by iceman504 View Post
    good advice...turn the key and see if you hear the pump prime. If not there's a relay under the hood you can check. Just swap it with the a.i.r. relay to see if the pump kicks on. If it still doesn't kick on your pump is probably toast. If you hear the pump kick on but it won't start then check your pressure at the rail...should be ~58 psi.
  1. Help: car wont start and now gauges wont work!
    By AB'sLs1 in forum General Help
    Last Post: 04-20-2013, 08:54 PM
  2. Z71 wont start
    By duranws6 in forum General Help
    Last Post: 01-09-2013, 07:49 PM
  3. LT1 wont start
    By Bad Co. in forum General Help
    Last Post: 11-18-2010, 07:23 AM
  4. LT1 wont start
    By Bad Co. in forum LT1
    Last Post: 11-16-2010, 05:32 PM
  5. car wont start
    By redss2000 in forum General Help
    Last Post: 06-20-2008, 01:06 PM
