    caraholic ggino85's Avatar
    most miserable city in the US
    blue green chameleon
    turn on right blinker, ALL lights blink??? HELP
    ok i have checked all bulbs and replaced the flasher, heres the deal. the other day i went to make a right turn and my blinker light didnt blink but you can hear a fast clicking sound coming from the flasher soleniod, i checked the left blinker it worked fine so i figure a light was out on the right side. All the lights but a sidemarker were ok so i replaced it and the flasher soleniod, now when i turn on the right blinker all the outside lights on the car flash/blink. the left works fine like it has been but when you turn on the right blinker both the right and left lights flash, the right side is a little bit brighter like its getting more power but they all flash. however when i turn i the headlights, the left blinker works but the right blinker light comes on and stays on like it would if a bulb was burned out?????? i have to pass a brake n light inspection and im clueless, HELP!!!!!!
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    did you get the right flasher? there are 2, one for hazzards and one for turn signals. Did you replace the turns flasher with a hazzards?
    Quote Originally Posted by JaycenK View Post
    no thats the samething i was thinking at first but the flasher is for hazzard and blinker, also the left blinker works fine its just the right thats making all the lights blink.......
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    If it is the right side it has to be a bulb on the right side or a bad socket. Check all the bulbs and sockets.
    Member fieropope's Avatar
    union mo
    01 formula
    sounds like a ground issue to me , my truck had done this in the past, went through the bulbs ,flasher,switch,nothin fixedit .got pissed and started checking the main grounds found one corroded over cleaned it and bam never happend again. well worth checking the ground first.
  1. turn signal doesn't blink but the light comes on
    By ajonesz28 in forum Camaro / SS
    Last Post: 03-23-2009, 03:02 PM
  2. Help: Turn Signals Light But Do Not Blink
    By sween in forum Camaro / SS
    Last Post: 04-05-2008, 07:29 PM
  3. help turn signals dont blink
    By Speedy_Gonzales in forum Camaro / SS
    Last Post: 05-26-2007, 11:55 AM
  4. Blinker won't blink
    By watson023 in forum General Help
    Last Post: 02-05-2007, 12:51 PM
  5. Blinker dont blink...
    By rovster in forum General Help
    Last Post: 11-16-2005, 01:42 AM
