Results 1 to 20 of 21
03-22-2009, 06:44 PM #1Junior Member
- Aug 2008
- LOS ANGELES
turn signal doesn't blink but the light comes on
My right turn signal comes on but doesn't blink it just stays on any thread or info on how to fix it
03-22-2009, 06:56 PM #2El Toro Grande
- Mar 2006
- Ponca City,ok
1958 chevy pickup 283- 02 gmc z71 5.3L white
burnt bulb
03-22-2009, 07:05 PM #3
yea, you have a bulb a bulb out on that side
03-22-2009, 07:13 PM #4
flasher fuse?
03-22-2009, 07:31 PM #5Member
- Roswell
Black- 1998 TransAm convertible
03-22-2009, 07:43 PM #6El Toro Grande
- Mar 2006
- Ponca City,ok
i had to replace 4
03-22-2009, 09:33 PM #7
03-22-2009, 09:47 PM #8Junior Member
- Aug 2008
- LOS ANGELES
How much does it cost and how do I replace it
03-22-2009, 10:24 PM #9Junior Member
- Baltimore Maryland
Red- 2002 z28
the bulbs are not more then 2 bucks or so, its probably your turn signal in the front so all you do is pop open the hood, find the turn signal, then find the gray colored piece that is on the back of the signal. Twist this a quarter turn or so and that whole piece , and the bulb will come out, pull out the bulb, put the new one in, and turn the bulb back in place.
I forgot to mention there are two of these bulb attachments, one is the turn signal and the other is the daytime running light , the one thats closest to the outside of the car is the turn signal bulb, the one closest to the center of the car would be the daytime running light
03-23-2009, 07:28 AM #10Junior Member
- Aug 2008
- LOS ANGELES
Im talking bout the taillight when I turn the right turn signal on the tailight doesn't blink it just stays on
03-23-2009, 07:38 AM #11Military Muscle :usa:
- Columbia,SC
Millienum Yellow- 2003 Corvette Z06
you have a burnt out bulb on that side of car its usually the front turn signal bulb thats out...cost no more then 2 bucks you can reach it from under the car by sliding under the right front fender locate the back of the housing and twist out the holder replace bulb then twist it back in...your DRL might be working but the trun is out
03-23-2009, 09:49 AM #12Junior Member
- Aug 2008
- LOS ANGELES
So how do you do the rear tailight I know how to do the front now I do I get the right rear tailight off to fix it
03-23-2009, 10:27 AM #13El Toro Grande
- Mar 2006
- Ponca City,ok
if the rear is staying on it means the front is burned out, you dont need to replace the rear, but if you want to any ways you have to unlock the plastic inside the hatch and pull the carpet back, there are to twist knobs that you take off by hand and the whole assembly comes out, then just twist and replace
03-23-2009, 10:34 AM #14
1)open hatch
2)pull interior panels back near tail light
3)loosen black thumb scews, remove and set them aside
4) pop out tail lens
5) locate socket which has burned lamp
6) sqweeze tabs and turn to release from lens back
7) pull out burned lamp from socket
8) replace
9) reverse steps 4-1
Alternative:
1) locate burned out side
2) take a sledge hammer out
3) smash the piss out of the lens
4) paint new bulb red or orange
5) replace burned bulb with painted one
6) lol
7) just kidding
8) lolLast edited by Smittro; 03-23-2009 at 11:46 AM.
03-23-2009, 11:50 AM #15
03-23-2009, 11:56 AM #16
03-23-2009, 12:45 PM #17
03-23-2009, 12:53 PM #18
03-23-2009, 02:03 PM #19Junior Member
- Mar 2009
- Broken Arrow, Ok
White with Red strips- 1967 Camaro
COME ON GUYS!!! your letting me down here... If the bulb comes on, but dont flash.. UUUMMMM it is going to be the flasher.. Thats the whole job the flasher does...A FUSE does not make it flash or not... A burnt fuse will make your lights not come on at all... But since there coming on, that leaves the flasher...
03-23-2009, 02:28 PM #20
The flasher was my first thought. That's how I've always dealt with that issue in the past. But, if these guys say to change a bulb...
Lots of things about this car that are different from the Chevelle's that I drove for 14 years. I learn something new all the time.
Guess I'll find out for sure when the issue arises in my Camaro.
New amber light harness and turn signal
By donkill in forum Stereo and ElectronicsReplies: 5Last Post: 03-06-2014, 05:50 PM -
Daytime running/ turn signal light color problem?
By draggo in forum Firebird / WS6Replies: 13Last Post: 08-26-2008, 02:25 PM -
Question: TA Turn Signal/Driving Light Fix?
By GULLETT17 in forum Stereo and ElectronicsReplies: 36Last Post: 07-23-2008, 06:28 AM -
Help: Turn Signals Light But Do Not Blink
By sween in forum Camaro / SSReplies: 15Last Post: 04-05-2008, 07:29 PM
Good to know
