Results 1 to 20 of 37
    Senior Member GULLETT17's Avatar
    Muncie, IN
    00 TA PWTR, 98 VertTA NBM
    80 TA BLK, 80 Formula NBM
    TA Turn Signal/Driving Light Fix?
    I did a quick search and couldnt find anything . . .I'm havin the normal corrosion problem in my driving lights/turn signals. Im on my second round of replacing both bulbs and now the drivers side socket/harness has corroded bad enough that it needs replaced. Has anyone modded their turn signal socket/harness to prevent it from corroding the contacts. On my 98 bird i drilled 1/8' holes in the housing to prevent moisture accumulation and burnout. But on the ta, with the socket comin in from the bottom its not this simple. So I was thinkin of simply drilling a small hole through the middle of the socket itself to release the moisture that acculates in there. Whats your guys take on this?
    2000 TA, A4, LS6 intake, Magnaflow, WS9 hood, BMR STB, UMI boxed SFC, Spohn LCA, 9" Ford
    1998 TA Vert,​ NBM, M6, Flowmaster, WS6 hood, WS6 airbox, C6 wheels, UMI SFC, BMR STB
    1998 Bird, Black, V6, A4, 18" 077's, Wings West Body Kit
    1980 Formula, NBM, 402BB, cam, DR timing, LT headers, 3" TD w/ flowmasters, TH350
    1980 TA, Black, 301, bone stock
    Muncie, IN
    new harness/socket . . . $60 gm from dealer , $9 from oriellys.
    Member qwk93ta's Avatar
    Fairfield, Ohio
    00 WS6
    Quote Originally Posted by GULLETT17 View Post
    Do you have a part number?
    Formula Driver! 96Firebirdformula's Avatar
    Seymour, Indiana
    Batman Black
    1996 Formula
    Why they call it the Stealership
    Houston, Texas
    2000 C5 Torch Red
    Yeah Gm quoted me 75 each 4 those. After you switch em out get some LED ambers and a new flasher unit for about 15 bucks. Your front signals won't ever get super hot again.
    Muncie, IN
    Quote Originally Posted by qwk93ta View Post
    nope . . . actual went to go pick it up from oreilys and it was the wrong one. it was for a round, turn it style. the guy looked forever on the computer tryin to find it, and come to find out it was really gonna cost $40 from there. but they had one out in the electrical section that said for 3157 bulbs for 4 bucks. i told him i was gonna try it. i got it installed and seems to be fine. what the hell is the difference in the ones they have to order?
    Muncie, IN
    i dont think theyre gettin hot, theyre just holdin moisture.
    Houston, Texas
    2000 C5 Torch Red
    Well the stock bulbs do cause some of the issues. Those 3157's get super hot and i bet if you ever remove the bulb housing you might find some cracks in the top. Can be caused from the plastic heating and then if it ever meets water (rain, car wash etc) it can potentially cause damage. I was able to keep my stock housings after I found they were cracked by reinforcing the top with JBweld and where the clear plastic on front meets the housing with silicone to seal it all back up. No leaks since then. Hope that made sense.
    Muncie, IN
    i do need to remove my turn signals housings and inspect them. . . you definately could be right about them bein cracked
    Muncie, IN
    alright bump for this thread . . another bulb burnt out. i think im gonna buy another new socket on the way hope from work and try to drill a drain hole in the bottom of it. see how that works for preventing this cuz its pissin me off
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Have you tried sealing the housing, bulb, and lens with some silicone to keep out the moisture? Also put some dielectric grease on the bulb base.
    Muncie, IN
    well after messin with it last nite, it does seem like my housings have a few stress/heat cracks in em . . . so im gonna try to get at least my passenger side out this w/e (its seems like the worst) and see what i can do. i use the dielectric grease evertime and never touch the bulb itself with my bare hands. i just think if the damn thing had a small drain hole to allow for moisture to escape, possible even heat, it would prevent so many burnouts. and its not like the bulb is really burning out, the prongs are just corroded so bad, they just fall off when you try to clean em.
    Fairfield, Ohio
    00 WS6
    Do you have a part number for an LED amber? I have this same problem.
    Houston, Texas
    2000 C5 Torch Red
    I found mine online at a ledlight site. If you go there they have a ton of variety in replacement 3157 bulbs. I got the 18 LED Light (49632)
    Fairfield, Ohio
    00 WS6
    Is it true that you have to replace the flasher to use a LED light?
    Houston, Texas
    2000 C5 Torch Red
    Yes. If I remember the flashers only like 5-7 bucks and only takes like 2 min to put in if your looking in the right place.
    Fairfield, Ohio
    00 WS6
    Thanks
    Fairfield, Ohio
    00 WS6
    Well I just fixed my turn signal.....replaced the socket and everything works. I bought a new socket from AutoZone. Without the part number know one at the store will be able to figure out what you need. The part number is 85881.
    Houston, Texas
    2000 C5 Torch Red
    Is that for 3157 bulbs? Thx for the info.
    Fairfield, Ohio
    00 WS6
    3357 is what I used.
  1. New amber light harness and turn signal
    By donkill in forum Stereo and Electronics
    Last Post: 03-06-2014, 05:50 PM
  2. turn signal doesn't blink but the light comes on
    By ajonesz28 in forum Camaro / SS
    Last Post: 03-23-2009, 03:02 PM
  3. Daytime running/ turn signal light color problem?
    By draggo in forum Firebird / WS6
    Last Post: 08-26-2008, 02:25 PM
  4. T/A Driving Light Turn Off Conversion
    By n.m.racer in forum Stereo and Electronics
    Last Post: 07-20-2008, 03:30 PM
