Results 1 to 16 of 16
    Fremont, Ca
    1998 SS
    Turn Signals Light But Do Not Blink
    I am a brand new member and this is my first post. I have finally got my SS (Black 1998) and am really enjoying it.
    Problem - The turn signals light, but they do not blink. The hazard flashers and back-up lights work fine. Brake lights work fine. Both turn signals worked fine and then they stopped blinking a few days ago.
    What do you think the problem is?
    Connecticut
    2000 Camaro SS M6
    Could just be a broken relay...cheap part
    Fremont, Ca
    1998 SS
    Where Is The Relay Located?
    Thank you for your quick reply? Can you tell me where th erelay is located?
    Georgia
    2014 Camaro 1LS
    welcome to the site...........I would try replacing the bulbs first, they can light up but still be bad causing it not to blink
    Junior Member joker_01z28's Avatar
    Colorado Springs
    Maroon
    2000 Silverado
    might sound stupid but check if the bulb is fully connected, mine was coming loose, same thing happened to me.
    That has happened to me before, I would try the bulb first as well.
    Painted manta stripe
    Fremont, Ca
    1998 SS
    Changed Bulbs - No Difference
    I changed both of the rear bulbs and the problem is the same. Turn signals - light goes on, stays on, does not blink. Hazard Flashers - work fine. Brake lights - work fine. Any other ideas?
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by sween View Post
    change the front ones
    Member ZForce1's Avatar
    Maine
    1999 camaro Z28
    changing bulbs will not work. If the flashers work then the bulbs are fine - that is how to troubleshoot finding one bulb being out amongst all of them. It is most likely the flasher unit under the dash that controls the turn signals.
    Fremont, Ca
    1998 SS
    How/Where To Replace Flasher Unit?
    Thanks. My next purchase will have to be the factory shop manuals!
    Can you tell me where the flasher unit is located and how it is replaced?
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by ZForce1 View Post
    I had the exact same problem and it turned out to be the front bulb
    Georgia
    2014 Camaro 1LS
    http://www.ls1.com/forums/showthread.php?t=51905
    There is a pic of the flasher in this thread...........unclip and unplug is all
    Member camaross19973's Avatar
    Los Angeles
    blue
    1999 camaro ss #976
    yes ck ur bulb i had same problem,has to be one of them.
    A friggin fish! LOL buswwa's Avatar
    Vernon, CT
    2000 Z28
    Also check the front turn signal housings for water. Both of my bulbs in the front went this week due to water collecting in the lense. Last set of turn signals I had this happen with actually melted due to the heat/water and the bulbs literally exploded. Oh, and enjoy getting to those bulbs. In case no one told you, you have to remove the headlight assembly to get to the front turn signals.
    FOR SALE 2000 Z28 M6
    It's pretty much Raw Awesome
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by buswwa View Post
    its much easier to change them from under the car. Just remove the bolt/bolts for the plastic flap to fold down
    Vernon, CT
    2000 Z28
    Eh, its either a few bolts form underneath, and I think one, maybe two to pop out the headlights. The design is to remove the one or two from the headlight, and then they just slide out as one piece. Ill let ya know after I change em tomorrow.
    edit Nope, it was defintitely easier to do them from the top. One bolt on the headlight housing, and disconnect the headlights. Slide the headlight housings out and the turn signals are right there below. The turn signal socket is even mounted on top, so I would bet its much easier then going in from the underside. Also, foglight bulbs are very easy to change once the headlights are out of the way.
  1. Help: turn on right blinker, ALL lights blink??? HELP
    By ggino85 in forum Stereo and Electronics
    Last Post: 08-25-2009, 04:40 PM
  2. turn signal doesn't blink but the light comes on
    By ajonesz28 in forum Camaro / SS
    Last Post: 03-23-2009, 03:02 PM
  3. help turn signals dont blink
    By Speedy_Gonzales in forum Camaro / SS
    Last Post: 05-26-2007, 11:55 AM
  4. RunnWS7's Fog Light and Turn Signals
    By KiD WiCKeD in forum Firebird / WS6
    Last Post: 04-24-2007, 08:50 AM
  5. Turn Signals
    By topgun1851 in forum General Help
    Last Post: 07-19-2006, 08:45 AM
