Results 1 to 18 of 18
    Junior Member watson023's Avatar
    Dallas
    '02 WS6
    Question Blinker won't blink
    I just replaced my front blinkers and they were workin fine for a few days, then the left one just stopped blinking. The lights all work, it just won't blink. This might be a stupid question, but what's wrong and what do I do?
    Check the bulb again and check that it has a good ground.
    Dallas
    '02 WS6
    Good ground? All I know to do is take out the old one, and put in the new one.
    Old man with an F-Body!!! Kajun Taz's Avatar
    Benton,Arkansas
    Red/Neutral(tan)
    '02 WS6/K&N airfilter.
    Also, when changing bulbs, DON'T touch the glass with bare skin, or the oils from your skin will burn it out PRONTO, as the "bright" element of the blinker bulb is also your daytime driving light... they get really hot and will go poof very quickly if contaminated.
    PROUD father of a United States Marine.
    38 of 139 PontiacFan's Avatar
    Kearney, NE
    2001 Pontiac
    Did you remember to refill the 'blinker fluid'?
    You can buy some here, http://kalecoauto.com/index.php?main...&products_id=6
    Quote Originally Posted by PontiacFan View Post
    Thats the same store I get my summer air for my tires at.
    Great link
    Benton,Arkansas
    Red/Neutral(tan)
    http://kalecoauto.com/index.php?main...products_id=20
    I really hope my wife NEVER sees this one, or I'm done for........
    Lets get this back on topic to help the thread starter guys
    Painted manta stripe
    Member Jon7I2's Avatar
    Chicago
    99 Formula M6
    U probably just didn't push the bulb in far enough. It should snap. I did the same exact thing a month or so ago, and then i realized the bulb was not completely snaped in. I know it sounds obvious but double check, sometimes car problem are just that simple.
    Member Stricken1's Avatar
    Florida
    2001 Trans Am WS6
    I had an issue in the steering column. If I would adjust the wheel it would cause the right turn signal to freeze. Try adjusting the wheel up and down and see if your turn signal starts working. If it is you have a short in the switch. Pray its just a bulb/ bad connection.
    Quote Originally Posted by watson023 View Post
    Is the right side blinking? If not I would look at the flasher but if it does blink I would do as others have said and recheck all the bulbs to make sure something isn't jacked up.
    DFW
    '18 CTS-V
    '13 ZL1
    has the right stopped as well? if so do this:
    check your turn signal indicator fuse that's located up under the dash and to the right of the steering column. you have to remove the panel under the sterring column in order to do so. it's round (feel for it) about 1-1.5" diameter.
    if not, check your bulbs are in/connected all the way.
    GypsyDude mr.5.7's Avatar
    Houston
    T/A.black.Tundra White.
    01 WS6.07Tundra DC
    Wink my turn lol
    i hate stealing this guys answers but all my signals are really slow in the other day the left parking light whent out it looks like my cars winking how do i make my signals fast again would a programmer help lol no foreal that any thing bad how do i fix thanks
    Dallas
    '02 WS6
    I don't have time to check them right now, but I would think that if there was a bad connection, the light wouldn't come on. The light comes on (I turned my hazards on and both back lights and the front right were blinking, but the front left stayed solid). So could it still just be a bad connection even if it lights up?
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Change the bulb & use a Sylvania ONLY.
    GE's will melt the base & crack the bulb.
    Then if you still have problems report here.
    DFW
    '18 CTS-V
    '13 ZL1
    Quote Originally Posted by mr.5.7 View Post
    read my post above yours. i suggest checking the turn signal indicator...
    lmpounded SandmanWs7's Avatar
    Dallas, Texas
    2007 CTS-V
    If your blinkers are starting to blink slower there is a chance that your flasher is going out. On my car when I first got it they would blink slow, then they stoped. When I changed it out they started to blink faster. So basically just change out the flasher and see if that helps. You should be able to find one at Vatozone for about $8.00.
    Dallas
    '02 WS6
    Well I went to the shop and bought a couple more signals, cuz I dropped and broke one of mine when checkin it out. I think the problem was that I didn't use bulb grease when I put them in the first time. I didn't know I had to. I think the problem was corrosion. I scraped some crap out of the socket, put the bulb grease on the base of the bulb, and hooked it up. Workin great so far, but I'll let ya know if anything changes. Thanks for your help guys.
  1. Blink 182 tomorrow night
    Last Post: 10-08-2009, 07:15 AM
  2. Help: turn on right blinker, ALL lights blink??? HELP
    By ggino85 in forum Stereo and Electronics
    Last Post: 08-25-2009, 04:40 PM
  3. Help: Turn Signals Light But Do Not Blink
    By sween in forum Camaro / SS
    Last Post: 04-05-2008, 07:29 PM
  4. Phuckin Monsoon on the blink AGAIN!
    By Z ROADSTER in forum Stereo and Electronics
    Last Post: 04-08-2007, 08:38 AM
  5. Blinker dont blink...
    By rovster in forum General Help
    Last Post: 11-16-2005, 01:42 AM
