Results 1 to 13 of 13
Thread: starting problem
05-25-2009, 08:04 PM #1Junior Member
- Nov 2005
- Lewiston, Idaho
red- 73 Z28
starting problem
My 01 TA manual 55K occasionally refuses to start. I used to just shut the key all the way off and try again but as time goes on it's getting worse. The other day I was making plans to get a ride, took about 5 tries before it started). Once it starts it runs fine. No real pattern to it, usually no more than once a week. I guess most often on a cold start but the other day it was hot.
Any ideas?
05-25-2009, 08:15 PM #2
05-25-2009, 08:20 PM #3
noticed anything with your "security" light? it might be the VATS. or does it actually crank but no start? if it doesnt crank and just all the lights on your dash light up then it might be the VATS.
05-25-2009, 08:29 PM #4Junior Member
- Nov 2005
- Lewiston, Idaho
red- 73 Z28
No lights and it cranks like mad. Hadn't thought of plugs, I'm used to small blocks that eat a set in less than 10k and run lousy. This one runs fine but it does get dogged around town.
05-25-2009, 08:38 PM #5
05-29-2009, 11:17 PM #6
05-29-2009, 11:19 PM #7
05-29-2009, 11:20 PM #8
05-29-2009, 11:34 PM #9
if it's turning over and your security isn't flashing then it's not vats. If shutting the key off and then turning it back on helps it would make me want to check the fuel pressure. Sounds like it could be the regulator nose diving on you.
05-29-2009, 11:34 PM #10
check ur wire nuts on starter , and leading to battery
05-29-2009, 11:37 PM #11
05-30-2009, 03:53 PM #12Junior Member
- Nov 2005
- Lewiston, Idaho
red- 73 Z28
I never looked at that chip in the key before. All they did was shove a surface mount resistor into a rubber mount. Yep, it's coded, in a stone axe analog sorta code. The bypass is a great idea and should cut down on the price of keys.
Mine measures 2.36K so it's a 2.4K. Wanna start a collection of the values, I can get resistors real cheap (.01ea @100).....might take some working out....
I was told there is a sensor that won't let it start w/o oil pressure buy there is no sign of leakage and I topped off the oil.
Thanks a bunch for all the ideas so far!
05-31-2009, 07:32 PM #13Junior Member
- May 2009
- Missouri
Blackq- 2001 trans am
I just had this same problem on mine. Look in your fuse box under the hood, There is a fuel injector relay, all the shop had to do on mine was like tap on it and the car starts fine every time now. hope thats all yours is. I forgot the percise fuse its call but try just adjusting them all. Gotta love pontiac!
Question: starting problem
By Faught in forum General HelpReplies: 6Last Post: 10-07-2010, 12:13 PM -
Starting problem.
By Hawk01Eye in forum General HelpReplies: 4Last Post: 04-11-2010, 08:03 PM -
Starting problem
By Da Wookie in forum General HelpReplies: 24Last Post: 07-17-2009, 07:50 PM -
Starting Problem !!!!
By ROLLIN1200 in forum GM TrucksReplies: 5Last Post: 09-21-2007, 06:06 PM -
need help with starting problem
By tds1213 in forum General HelpReplies: 3Last Post: 06-20-2007, 07:46 AM
