    Dec 2008
    San Diego
    1999 Trans Am WS6
    Turn signal not working
    ok so i am sure this might have been discussed before but i have a 1999 trans am and my 2 front turn signals are all corroded out. the lights dont blink when i use the blinkers but work just fine when the headlight are on. i was told i need new connectors but have no idea where to find them. i have been through like 20 bulbs in the last month and it is like a daily routine to change the bulb when i start the car and i am tire of it. i just want it to work when i start it up and stop burning out. i already have a new set of housings and 2 new bulbs but i want to get a new connector first. any and alll suggestions are welcome. thanks
    florida
    2002 Firehawk
    Go to a local salvage yard find a Pontiac cut wires about 6" long make sure
    color of the connector is GREY that is what is used on the Firbird & Ta. Remove your
    defective connector and reconnect the three wires blue to blue, brown to brown,
    and black to black. You can solder the wires or crimp. Should take you about a hour.
    PROBLEM SOLVED.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    brand new connectors.. 8 bucks.. autozone
    Livonia mi
    blue
    I had the same problem with my 99 ta you have to clean them with baking soda and water and compressed air. if this does not work then replace the whole socket which are fairly cheap. Good luck!!!
    Member knightryda01's Avatar
    May 2008
    Michigan
    midnight blue
    2000 Pontiac ram air ws-6
    I went to autozone they said they don't carry that... dealer part only. I need that part the bulb actually sets in.
    Beaver Dam KY
    79 T/A -91 Firebird
    Quote Originally Posted by knightryda01 View Post
    jesus this is the 50th time ive seen this. it is a generic wedge base 3 prong socket.
    Go walk over to the bulbs and look...
    Dec 2008
    San Diego
    1999 Trans Am WS6
    so i can get the socket connector at autozone but it is not really make for the trans am, just a gerneric piece that fits perfectly?
    Beaver Dam KY
    79 T/A -91 Firebird
    Quote Originally Posted by trans_am7935 View Post
    Yup. Kinda like ordering oil for trans am... they would refer you to a dealer lol
    lmpounded SandmanWs7's Avatar
    Dallas, Texas
    2007 CTS-V
    http://www.ls1.com/forums/showthread.php?t=68563
    (turn and stop socket with ground tab)
    $6.99 @ autozone. part number 85881
    Beaver Dam KY
    79 T/A -91 Firebird
    Quote Originally Posted by SandmanWs7 View Post
    You are the shit
    Part number FTW
    Auto Painter RyanJM's Avatar
    Houston, TX
    You can also get the from Advanced Auto if Auto Zone doesn't have them. I needed 2 and the Auto Zone near me had one.
    Dec 2008
    San Diego
    1999 Trans Am WS6
    thanks a bunch, the part number really helped after trying to explain something to someone that really didnt speak english in the first place. so i gave him the part number and i was out of there in 5 min!
  1. tired of having a non working turn signal...
    By Ws6islife in forum Firebird / WS6
    Last Post: 11-18-2010, 05:42 AM
  2. Driver side turn signal no working? WTF!
    Last Post: 09-17-2007, 07:20 PM
  3. Turn Signal Cam
    By shlby123 in forum Firebird / WS6
    Last Post: 03-20-2007, 01:15 PM
  4. Turn Signal PLEASE HELP
    By TA2FST4U in forum General Help
    Last Post: 06-01-2006, 07:35 PM
  5. Turn Signal not working
    By ak1 in forum Stereo and Electronics
    Last Post: 05-16-2006, 01:16 AM
