Page 1 of 4 1234 LastLast
Results 1 to 20 of 64
    Member matthewaqui's Avatar
    Lakewood, California
    Red/Silver/Black/Red
    TA-G8-Expe-L200-Camaro
    Post Turn Signal Socket- Where to Buy
    I looked all over the Forum and practically search half the Internet on a Turn Signal Socket.
    They are sold on Ebay for an Arm and a Leg. The dealership sells them for $70 bucks.
    If your turn signal blinks a couple time then stays lit... or don't blink at all, it's probably due to the rusted corrosion in the blinker socket. Vehicle washing result in water sitting within the socket.
    Use a 10mm socket to unscrew the two under engine bottom panel bolts to reveal the front light sockets. This is much easier than trying to stick your hand through the vent to reveal the socket.
    Either at Autozone or their website is where you can pick up the sockets for the best price. Here is the info brother!
    Trans AM DRL harness/wiring
    (turn and stop socket with ground tab)
    $6.99 @ autozone. part number 85881
    I suggest buying some super grease to lube the plug before installation of the bulb. This way, water will not be able to find it's way in.
    Formula Driver! 96Firebirdformula's Avatar
    Seymour, Indiana
    Batman Black
    1996 Formula
    Were i got mine from autozone worked perfect
    Thumbs up Thanks for the Review
    Thanks for the Review on the part man! It'll be helpful to many LS1 owners with this problem.
    Last thing I forgot to mention........ there were two missing panel bolts to the underside of the vehicle..... while you guys are down there, you should use your 10mm sockets to tighten up all those bolts. It'll save yourself the trouble of purchasing new ones..
    Matt
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Had to replace both of mine lats month. 7.99 autozone They are listed as tail light sockets. they work. i think they are listed as 88-96. They work tho!!!!
    Thumbs up Super
    Thanks for the confirmation--------
    The part can also be purchased from Kragen Auto Parts for $7.49 with the same part number.
    Whatever the case, seal the socket up is a necessity to make sure that it doesn't go bad again.
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    Make sure that you don't have any cracks in the housing. I tried the sealant and everything on mine, but when the water sits on it for a long time it just degrades the grease and gets in there anyways. The housing should not be getting any fluids inside. I replaced both of mine because there were micro cracks in them and I haven't had a problem with them since. Plus, the new housings have a reflective coating in them and they look a lot brighter than they did before.
    Post Drilling Some Holes- Water Release
    As I was checking out how the socket sit inside of housing, horizontally speaking, water settled inside of the socket after a wash. I haven't replaced the socket as of yet, but I think the wear and tear will be minimized if the socket sat vertically with the bulb pointing down in the housing. For this to happen, one would have to cut a hold in the housing..................
    Another thing that could be done is to drill a couple holes in the housing so that the water will not reside in the housing. The Drilled water hole release can also be performed in the License plate well in front and rear of the vehicle. Water Typically reside their and deteriote the clear coat after a wash if you don't dry well.
    Matt
    Quote Originally Posted by Mike's TA View Post
    Austin, TX
    99 Trans Am(sold)
    I drilled the holes before replacing the socket and not a week after I drilled the holes my driverside lens cracked like crazy. Don't know why. Best advice is to get new ones.
    Wink Brittled
    Those lens are very brittle Mike, especially when they are old. I doublt it cracked from your drilling. It's probably due to road debri....
    Austin, TX
    99 Trans Am(sold)
    Sorry, Didn't mean to make it sound like the drilling cracked it. Just that it didn't help any.
    Beaver Dam KY
    79 T/A -91 Firebird
    I keep blowing lights everytime i go in the 10 dollar laser wash/wax. My fog and turn signals are hairline cracked... since I got the car. Im on light bulb #7 right now... .. lol
    Austin, TX
    99 Trans Am(sold)
    Replace the housings, and stop going through the auto washes. Those things can do some damage.
    Greensboro, NC
    2002 Trans Am WS6 M6
    Angry
    My DRL flooded during the last heavy rains and shorted the socket and the bulb so after reading this thread i took a trip over to autozone to get a new one today. I checked online to make sure they carried it and had it instock at the local store near me. I got there gave the salesperson the part number that it uses and she swore up and down it didnt exist. I tried telling her its on the website and everything but she didnt believe me . So i just walked over to the place where they kept the sockets and low and behold there it was, so I walked up to the counter to pay for it with a nice smug smile on my face. If her head could of exploded it would have. But the day gets better not two blocks from my house a cop pulls me for not using my turn signal, I showed him the parts and told him I was about to fix it but he didnt care he still gave me a ticket for it .
    Member ldanny's Avatar
    kemah,TX
    00 Formula M6
    Thumbs up
    yep just got mine saturday from autozone as well came with butt connectors as well.
    weberje
    Guest
    Great Info!!!
    Think I'll be taking a trip to autozone. Thanx guys! Oh, and I think I will nix the drilling weep holes and go for RTV (Room Temperature Vulcanizing) sealant. Is what we use on our jets, so must be somethin to it!
    peace.
    Thumbs up The Shitzzzzzzzzzzzzzzzzzzz
    Boy! You sure had a shitttttty adventure with the light. Hope you had a fix it ticket rather than a balance due one. Since I brought this thread up, it sure shows how many out there are having problem with this socket thing! Glad I can point it out to many.
    Only if that counterperson at Autozone could of checked their system for inventory, it would of shown it's in stock. That part number actually works for Kragen and many other stores as well. Those socket will run the lowest for $26 bucks on EBAY. Speak about and arm and a leg. Hope you purchased two and replaced the both of them.
    I will purchase and replace mine this Saturday... seal it up good upon installation......pipe putty or some other sealant would be much better than grease.
    Matttttttttttttttttttttttt
    Wink Not In Stock.......................
    Yah.. that sealant would be the best, though you have to do it in a way where replacement of the bulb may be a necessity in the future......it's not the water getting in, it's the rust that evolved which is the problem. I couldn't believe how bad it looked upon inspection after purchasing the used 2000 TA.
    Thank Heaven you guys don't live by me..... you would be purchasing all these sockets before I get to the store this weekend.
    Matttttttttttttttttttttttttt
    Greensboro, NC
    nope nice lovely ticket since he considered it a moving violation instead of something that was broken. the best part is i live in the city of greensboro but the neighboring highpoint cops patrol our area and they are a bunch of assholes they will pull you for anything they can find.
    Lightbulb Sealed Socket Bulbs...........
    Even though the Officer was a jerk about the signal, you probably would of had a good argument with him if you stuck your hand out and used a right turn signal! hahahahaha
    Hell man, my turn signal blinks a couple time and just plays dead... it's the corroded rust contact.
    Drop a dime and purchase some sealant so you don't have to deal with it for the next couple years.
    I'm going to replace both sides this weekend....
    As a matter of speaking, I wonder if we can get bulbs already sealed in the socket as a one piece..... that would sure be better.
    Mattttttttttttttt
    Greensboro, NC
    Probably could have argued till blue in the face and still would of gotten it. My driving record is a little on the long side though clean for 3 years now, well it was until today, but they dont care all they see is the dozen or so speeding tickets, multiple wrecks and a street racing ticket that got reduced to excessive speeding on my record from my more wreckless days.
  1. Turn Signal/DRL Socket and Lamp venting
    By Whamhammer in forum Firebird / WS6
    Last Post: 02-28-2014, 04:01 PM
  2. '02 turn signal bulb socket
    By johnfin in forum Firebird / WS6
    Last Post: 02-06-2013, 05:11 PM
  3. Question: Turn signal socket replacement
    By 2000blackbird in forum General Help
    Last Post: 10-25-2012, 07:02 PM
  4. turn signal socket
    By red99ws6 in forum General Help
    Last Post: 02-24-2008, 11:33 PM
  5. turn signal socket
    By camarossf650 in forum Camaro / SS
    Last Post: 07-23-2007, 06:45 PM
