Results 1 to 17 of 17
09-14-2007, 07:45 AM #1
Driver side turn signal no working? WTF!
it just show a solid arrow pointin right and it doesnt flash? replaced the bulb didnt work looks all wet in there what else can i do to try and fix it?this is
second time its stop workin first time the bulb was shattered
2006 IBM GTO A4
20% sides/rear 35% Windshield,SAP Repos,Ruff 278s Staggered 18s,LT's,Catless mids,Spintech Mufflers/X pipe,Torquer v.2,Vig3200 Stall,HPTuned,AEM CAI,SLP Thermostat,IAT relocate,BMR Drag bags, P4000DVD HU.
2000 TA WS6 NBM A4 Full Bolt-Ons-Gone
09-14-2007, 08:02 AM #2
i would replace the socket.. if thats not it then its the wiring
09-14-2007, 09:52 AM #3
There are lots of threads about this issue.
Check the lens on the housing. It might have some small cracks in it allowing water to get in. I wouldn't recommend replacing the socket if your lens has cracks. Replace the housing first. If your socket is degraded then replace it also. If it's not, allow it to dry up and clean it out. Should be just fine.
Main thing is. Find out how water is getting in the housing first.
My driver side housing cracked real bad and my socket got corroded horribly. I replaced the housing ($45) and the socket ($65) and it works fine now. I checked the passenger side housing and there were a few tiny cracks in the lens, a little bit of condensation inside, so I went ahead and replaced it to save the $65 on the socket.
09-14-2007, 09:55 AM #4
thats insanely expensive for the small light!
09-14-2007, 10:06 AM #5
Light housings are not cheap. You will save money by making it work properly though. Think about all the bulbs you would have to buy otherwise. And the possibility of getting a ticket for "Failure to Signal Intent". I got one once in a different vehicle and it was $285. He wrote me for that cause he couldn't get my speed, but he knew I was speeding. And I know that I signaled the lane change, cause I always do. Even in traffic at 90 mph.
09-14-2007, 10:41 AM #6Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
I just fixed this same issue in my Camaro yesterday except it was the passenger side.
09-14-2007, 12:39 PM #798T/AformulaGuest
Mine was just doing the same thing and I ended up replacing the actual turn signal solenoid, the thing that ticks under the steering wheel, you could try it its under ten bucks to replace and prolly needs it anyways....
09-14-2007, 01:03 PM #8
I Just Replaced The Housing On Mine, 29 Dollars Shipped On Ebay Check It Out. Better Than 45
09-14-2007, 01:11 PM #9
The Dealer Replaced The Turn Signal Solenoid On Mine And It Has Never Worked Right Since,my Blinkers Dont Work In The Front And The Daytime Running Lights Dont Even Come On. The Only Way They Will Come On Is If The Lights Are On, But The Blinkers In The Back Work, Crazy Shit, And The Turn Signal Arrow Blinks As If Everything Was Working Correctly.
09-15-2007, 08:29 PM #10Junior Member
- Aug 2007
- Pueblo West
Arctic White- 1999 Pontiac Trans Am WS6
Same Here
I am having the same problem, I replaced both blinker solenoids (that is right, there are 2 of them) the other one is almost exactly opposite the one behind the stereo. Still didn't fix my problem. The side marker lights work like they are supposed to. Just the turn signals don't. gonna take it to the local lube place to get them to change the turn signals. Not skinny enough. maybe I will try ramps tomorrow. I dunno.
Pat
09-15-2007, 08:40 PM #11Freezin in AK!
- Aug 2007
- Anchorage AK
Old: 00 WS6, 02 Z06, 79TA- 11 F350 CC 6.7L
Im having the exact same problem with my passenger side, i get the solid light in the dash, the rear taillight blinker comes on but doesnt blink, the front doesnt come on at all. Im gonna try replacing the blinker module under the dash but i think after reading this ill check the housing for corrosion too.
09-17-2007, 11:11 AM #12
try buying a flasher at autozone.....NOW!
09-17-2007, 11:27 AM #13
i took my housing and wire thing apart and cleaned it with contact cleaner, q tips and an old toothbrush and its workin so im hopein this holds up
09-17-2007, 06:58 PM #14Crazy JoeGuest
Also it could be one of the rear taial light bulbs going bad thats what happend to mine
09-17-2007, 07:00 PM #15
dood im telling you guys ..same thing happened to me a year ago....i had my friend replace the flasher(i believe it was located under the dash)..and problem solved...whats with cleaning things? lol
09-17-2007, 07:06 PM #16
My right turn signal did same thing had a bad groundwire so i went to autozone and bought a new socket fixed it up for like $15
09-17-2007, 07:20 PM #17
ahh yes i c
Driver side turn signal lamp on when lights are off????
By BigLT42 in forum General HelpReplies: 2Last Post: 02-26-2012, 08:37 PM -
tired of having a non working turn signal...
By Ws6islife in forum Firebird / WS6Replies: 0Last Post: 11-18-2010, 05:42 AM -
Turn signal not working
By trans_am7935 in forum Firebird / WS6Replies: 11Last Post: 05-20-2009, 06:55 AM -
CAMARO Z28 SS Driver's Side Turn Signal
By chae in forum Parts For Sale / TradeReplies: 3Last Post: 07-16-2007, 08:54 AM -
Turn Signal not working
By ak1 in forum Stereo and ElectronicsReplies: 2Last Post: 05-16-2006, 01:16 AM
