Results 1 to 11 of 11
Thread: How do I remove this?
11-30-2008, 03:21 PM #1
So I took off the airbag sticker on the passenger side sun visor. It left some of the sticker backing on the cloth. Any idea what the best way to remove the left over backing off the cloth is? I bissell cleaner vaccum, thought about trying that but thought I would run it by you guys first.
11-30-2008, 03:31 PM #2
rubbing alcohol is decent at removing adhesives, trying scrubbing it with a soaked paper towel or something
2002 z28-slp cai, slp loudmouth, slp tuned headers, slp 85 mm MAF, slp high flow cats, 3" y-pipe and collectors
331.6 rwhp/356.9 rwtq
12-01-2008, 07:01 AM #3
regular old lighter fluid works really good too, also takes out lots of stains.....just try it somewhere you won't see to be sure it doesn't pull the color
12-01-2008, 09:21 AM #4
another trick that works too is using duct tape and sticking it to the visor and ripping it off some times it works
12-01-2008, 11:28 AM #5Senior Member
- Feb 2006
- Orange County, NY
If the other things dont work try some white vinegar and water mixed.
12-02-2008, 04:21 AM #6
You can use a utility knife, and cut around it.
SteveC
12-03-2008, 03:44 PM #7
acitone it drys fast and leaves no residue..try it in a spot first ...do not use any oil based anything on cloth.
12-08-2008, 07:46 AM #8
I used the product called OOPS worked great and smell is ok.
12-08-2008, 07:50 AM #9
Sometimes on fabrics, if you freeze the area, you will be able to pick it off. Worth a shot.
12-12-2008, 05:52 AM #10
12-12-2008, 10:01 AM #11
Question: how can i remove this
By robs98mysticZ in forum Showcar and DetailingReplies: 15Last Post: 07-07-2012, 09:19 PM -
Question: keep or remove? if so.. how?
By saucycrossover1 in forum Appearance SectionReplies: 15Last Post: 09-25-2010, 12:32 AM -
how do i remove pcm
By jmatt07 in forum General HelpReplies: 3Last Post: 03-17-2009, 11:32 AM -
how to remove gto from FRC's?
By Frankthetank in forum Appearance SectionReplies: 5Last Post: 10-26-2007, 01:15 PM -
remove eng from the top?
By H8S2W8 in forum Internal EngineReplies: 12Last Post: 12-01-2006, 04:24 AM
