Results 1 to 13 of 13
    Aug 2008
    Orleans, IN
    2002 Camaro SS
    stall converters
    I'm thinking about trying to get one for my car sooner or later and just wondering which you all perfer...
    Make real real sure Johns00Z28's Avatar
    Germantown, MD
    2000 Z-28
    Yank 3600
    Aug 2008
    Orleans, IN
    2002 Camaro SS
    do you have one on ur car? if so what kind of gains did you get out of it?
    Germantown, MD
    2000 Z-28
    Yeah I do have one on my car, haven't ran it yet but I've been told anywhere from .5 to .7 in the quarter mile. It really will wake your car up.
    Aug 2008
    Orleans, IN
    2002 Camaro SS
    wow thats a big difference just for that... guess I need to do more research and see what I can find and compare everything.... thanks for the info
    Germantown, MD
    2000 Z-28
    From what I've seen, Yank and Vigilante seem to be a couple of the top companies. You might want to search the automatic section for more info and other people's opinions though.
    Aug 2008
    Orleans, IN
    2002 Camaro SS
    okay thanks... gotta find my way to it... LOL don't hang out here to often
    Senior Member 440 rwhp trans am's Avatar
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    spend the extra money and get a yank. trust me!
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Wink
    Quote Originally Posted by najaf4life View Post
    There is a little more involed then just a converter, you will need an aftermarket transmission cooler (B&M 24K), a TranGo shift kit.
    Some other things you may want to consider is a deeper transmission pan, and a TCI SF29 race grade flexplate (if your vehicle is an 01 or 02).
    With a stall of 3600, you will need to have the computer settings modified for TM, shift points, idle (depending on OD of the TC), misfires. You will need to have this done on a dyno, for I do not believe a hand held device will ever get it right.
    Just some things to consider.
    SteveC
    Houston, Texas
    94 Formula
    Is the computer the problem now??
    I just had a 3000 stall put in mine and now it seems the shift points are off and it is misfireing at WOT, I should hve read this first. Now I have a new trans but can't drive fast.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    Quote Originally Posted by erhardtm View Post
    computer tuning will fix that.
    i have a tci 3000 streetfighter trans. i shaved off .6 tenths of my times.
    with a stall, you need a shift kit, oil cooler and tuning.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Arizona
    I gave Fuddle a shot after Orion had recommended and had good luck with them. They were a sponsor here at one time and I think recently took on new management.
    Anyway, I received mine and installed it. Great converter so far. Although I have a track record of my car with various mods,,,I cannot comment on the improvement of the converter at the track as of yet,,,I still need to install a trans cooler so I am refraining from any track time until then.
    I did have to go into the tune and lower the engine misfire settings,,,that was it. Didn't need to change any shift points at all,,,a sign of a good converter that isn't blowing through the shift points. May be a different story though as the engine makes more power.
    Albuqueruque, NM
    Vigilante 3200
  1. stall doesnt...stall
    By JacobLS1 in forum Automatic Transmission
    Last Post: 09-30-2012, 06:41 PM
  2. to stall or not to stall that is the question
    By Bandit1 in forum Drivetrain
    Last Post: 07-08-2008, 07:26 AM
  3. Replies: 15
    Last Post: 07-02-2007, 01:49 PM
  4. advice on stall converters?
    By shua01ss in forum Automatic Transmission
    Last Post: 08-03-2006, 06:28 PM
  5. converters
    By lawdog in forum Camaro / SS
    Last Post: 10-26-2005, 08:56 AM
