Results 1 to 19 of 19
Thread: converters
10-24-2005, 06:28 PM #1Member
- Oct 2005
- Oklahoma
Sunset orange- 01ss,85 pu,04ramdsl
converters
how do i go about properly doing away with the converters?
10-25-2005, 08:41 AM #2
taking them out, then tuning out the rear o2's...or you can put in o2 sims.
10-25-2005, 12:33 PM #3Member
- Oct 2005
- Oklahoma
Do I need to reprogram the computer?
10-25-2005, 12:34 PM #4Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Converter??
10-25-2005, 02:11 PM #5Member
- Oct 2005
- Oklahoma
I guess I still need more info.How do I do this the right way?If I pull the front two O2 sensors how do I tune out the rear?And if I use O2 sims will I get a check engine light?How do I do away with the front O2 sensors?I thought the fuel system needed all 4 to get the air to fuel mix right?
10-25-2005, 02:20 PM #6Blown, Stroked, & Sprayed
- Aug 1999
- No Where
You can't get rid of the front O2 unless you do a SD tune.
10-25-2005, 02:48 PM #7Member
- Oct 2005
- Oklahoma
pardon my ignorance?but an sd tune?Can you explain?
10-25-2005, 02:52 PM #8Blown, Stroked, & Sprayed
- Aug 1999
- No Where
I guess the most important question is why would you want to remove the front 02's?
Speed Density Tune.
10-25-2005, 02:56 PM #9Member
- Oct 2005
- Oklahoma
what I want to do is do away with the stock flattened Y-pipe and the converters?Figured if i didn't do away with o2 sensors I'd keep getting ses light?
10-25-2005, 02:59 PM #10Blown, Stroked, & Sprayed
- Aug 1999
- No Where
You can remove the cats and rear 02's. Either get sims or tune the rears out.
10-25-2005, 03:10 PM #11Member
- Oct 2005
- Oklahoma
I have a 01 ss with 4 o2 sensors so I guess i need to know what all do i need to do so I can do what I want to do.Is it possible to do what I want?
10-25-2005, 03:13 PM #12Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Yes, check out our sponsors for a new Y-Pipe and 02 sims.
10-25-2005, 03:17 PM #13Member
- Oct 2005
- Oklahoma
Thank you sir I have access to stainless pipe and computer controlled benders so figured I'd build it.Just need to know do i need 2sets of o2 sims or 1?? If I need just one how do I go about getting rid of the others?
10-25-2005, 03:18 PM #14Blown, Stroked, & Sprayed
- Aug 1999
- No Where
You need the front 02's, you can remove the rear set of 02's and replaced them with sims.
http://www.thunderracing.com/catalog...&vid=3&pcid=54
10-25-2005, 03:29 PM #15Member
- Oct 2005
- Oklahoma
So when i build the new Y-pipe I need to put in two o-2 bungs (one each side) and then just put sims on the rear set?I won't get the SES light with this config.?
10-25-2005, 03:36 PM #16Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Correct.
10-25-2005, 08:05 PM #17
the pre-cat o2's help the comp determine a/f ratio...so you need those unless you switch over to a speed density setup, which you don't need. the after-cat o2's show if the cats are working properly or not by comparing the o2 before and after the cats.
I've heard a few cases where the car threw a code when having sims...so you might wanna have them tuned out....
10-26-2005, 03:51 AM #18Member
- Oct 2005
- Oklahoma
what do i do to tune them out?
10-26-2005, 08:56 AM #19
you'll need a professional to tune them out...unless you own the proper software (hpuners, ls1edit...) and a laptop. That runs from 150-450 if you want to get it dyno tuned. Depending on how much money you have...i'd do the FRA mod, port the TB(about 125 on s2performance.com...or free if you have the know how and tools). Put a 2.5 in y-pipe and remove the cats like you wanted...and get some pacesetter long tube headers(350 or so). Then have it dyno tuned and they'll remove the o2 codes along with tune your car.
Converters
By dart in forum Automatic TransmissionReplies: 11Last Post: 12-24-2010, 03:21 PM -
stall converters
By najaf4life in forum Automatic TransmissionReplies: 12Last Post: 11-16-2008, 05:50 PM -
ACC Converters
By Louie_D in forum Automatic TransmissionReplies: 2Last Post: 11-27-2007, 03:26 PM -
catalytic converters
By bulljock in forum General HelpReplies: 21Last Post: 10-08-2007, 08:37 PM -
Catalytic converters
By samson_420 in forum External EngineReplies: 4Last Post: 10-08-2007, 07:40 PM
