Results 1 to 16 of 16
06-18-2007, 06:19 PM #1Member
- May 2007
- Columbia, MO
Medium Blue Metallic- 1999 Pontiac Trans Am
How does the stall converter behave, does the car move below stall speed?
I am rebuilding the trans and am thinking about getting the 9.5" 3000 stall converter from performabuilt. However I am imagining it as though I have to mash the gas and it revs to 3000 before jerking forward and breaking my neck, all day long. Since this is my daily driver I do not want much shock. In other words, will it start moving on its way up to the "stall" speed (stock moves the car uphill idling).
06-18-2007, 06:27 PM #2Junior Member
- Feb 2006
- Lisle, Illinois
quicksilver metallic- 2002 trans am WS6
just drive the car normally, it just takes car a few more rpms to get moving from a stop, it won't flash up to 3000, then take off. I have a 3600 stall, and it's not bad at all. A 3000 stall is a great DD stall.
06-19-2007, 09:32 AM #3Member
- May 2007
- Columbia, MO
So will it move at idle or 1500 rpm?
06-19-2007, 11:27 AM #4
I have a 3600 and it moves at idle but very slow not like stock. let off the brake and it will slowly start moving if thats what you mean.
06-19-2007, 11:47 AM #5Junior Member
- Mar 2006
- Michigan
red- 1994 Camaro Z28
Driving with a Stall Speed 'Vertor
The car WILL move before you reach stallspeed...that is the manufacturer's spec for "power braked" maximum rpm or , in some cases, the "flash rpm" if you instantly floor the accelerator at a standstill. In normal driving, however, the sensation is one of "slippage" inasmuch the engine reaches higher (not maximum stall) rpm before motion begins....The higher design stall speed ...the more the "slippage" sensation will occur.
The intent is to let the engine reach higher rpm/'s before it is "loaded"...to accomodate the torque curve of greater duration/lift camshaft characteristics. Of course, using a higher stall speed convertor on the street compromises fuel efficiency. ANother significant side effect is increased heat in the trans fluid, which obviously mandates using an external, aftermarket trans cooler.
06-19-2007, 02:31 PM #6Member
- May 2007
- Columbia, MO
Thanks that is exactly what I was asking. I guess I was thinking stall speed meant when it would grab, not power braked. Makes much more sense that way. So say my car is at 2700rpm going 75mph and I have a 3500 stall converter, will the converter still lockup below stall speed?
06-19-2007, 05:23 PM #7Junior Member
- Mar 2006
- Michigan
In the conventional sense of "locking up"..meaning the pump, stator and turbine are at the same speed....no...you will experience convertor "action" at nearly any speed, the differential of the pump and turbine speeds being dependent on throttle position.
Newer "lockup" convertors, on the other hand, usually are programmed so the clutch engages only under light throttle loads, and at minimal rpm. This has nothing to do with the amount of "slippage" designed into the convertor itself.
06-20-2007, 12:09 PM #8Member
- Mar 2007
- NC
NBM- 1998Z28
06-20-2007, 03:54 PM #9
06-20-2007, 07:20 PM #10Member
- May 2007
- Columbia, MO
So what mph is stock lockup speed set at?
06-21-2007, 01:54 PM #11
dunno mine is grossly off due to gear change.
06-23-2007, 03:03 AM #12Junior Member
- Mar 2006
- Michigan
06-23-2007, 10:07 AM #13Member
- May 2007
- Columbia, MO
So if most of my driving is >50mph my gas mileage will not suffer to much from the 3000 stall converter as opposed to stock?
06-23-2007, 02:10 PM #14
Ya its only the take offs that will cause the decrease in gas mileage as it will still slip some taking off. As far as highway driving is concerned you won't know there is a stall so long as you don't nail it.
06-27-2007, 06:55 PM #15Junior Member
- Mar 2006
- Michigan
going for gas mileage with /without a stall c/vertor means going above the overdrive minimum shift point, and convertor lockup speed...at that point, you will be optimizing fuel efficiency...as i said in earlier comment, typically around 45 mph with stock gearing in many cars....hope that helps..
07-02-2007, 01:49 PM #16
Mine was set at a dyno tune @ 43MPH. I have 3.73 coupled to a Y3000 2.0STR.
SteveC
need stall converter
By dicks99ta in forum Parts Wanted / TradeReplies: 3Last Post: 04-14-2007, 09:05 PM -
Stock w/ 3400 stall converter VS stock 6 speed?????????
By greatwhiteZ28 in forum Camaro / SSReplies: 11Last Post: 03-04-2007, 01:02 PM -
Stall converter
By justincw23 in forum Firebird / WS6Replies: 18Last Post: 12-13-2006, 06:45 AM -
Missing stall converter and idle speed
By earsti in forum DrivetrainReplies: 5Last Post: 11-29-2006, 08:42 PM -
Stall Converter Help
By Tonys99RamAir in forum Automatic TransmissionReplies: 11Last Post: 10-15-2005, 08:48 AM
