    Junior Member earsti's Avatar
    Feb 2006
    Dallas
    Black 2000 Z28
    Red 2006 GTO
    Missing stall converter and idle speed
    I had my A4 tranny replaced last March because it got caught in rising flood water. Nothing special but I had a 2800 stall in it. So the pump goes out on it last month and I take it back for warrantee work.
    When I get it back the idle is off. It will idle at 950 at the light, but I driving on the interstate and I shift to N, it idles at 1500-2000. It has driven me crazy. The shop says they cleaned the MAF and the filter. So, I think about getting it tuned, but I balked at the $500 they want to charge. So I'm thinking the shop damaged the MAF. So I order a new one. At the same time I pull the IAC and clean it. Pull the throttle body and clean it.
    Before I can install the new MAF, my son asks me to spin the tires for some of his friends. I hit the gas and not much happens. I start watching a little closer and the tranny's not slipping like it did. So I have taken it back to the shop and am fighting with them about putting in a 2800 stall and pulling the OEM out.
    So here's my question, if I was running with a 2800, then go back to a non slipping torque converter, would it cause my idle to be off?
    Thanks for your help.
    College Station TX
    2000 &2002 Z28
    I think it could if you have a bigger than stock cam in there and it was tuned for that stall. THe reason I think so is that its used to having that stall area and not having to put so much out just to idle. Now it is under a greater load at idle causing it to idle lower....Thats what Im thinkin but go ahead and correct me if im wrong guys.
    Feb 2006
    Dallas
    Black 2000 Z28
    Red 2006 GTO
    It does have a stronger cam. I forgot to mention it.
    Before I bought the car, it was tuned with the cam, a head job and the stall converter.
    Thanks,
    Sounds to me like the problem is in your tuning. If you put a stock convertor back in there and were tuned for the 2800, that should be the problem. Either get the 2800 verter back in, or get retuned for a stock verter.
    Painted manta stripe
    College Station TX
    2000 &2002 Z28
    thats what I was trying to say
    Feb 2006
    Dallas
    Black 2000 Z28
    Red 2006 GTO
    Thanks guys for the info.
    Earl
  1. Question: Stall Converter
    By one_fast_z28 in forum Automatic Transmission
    Last Post: 11-28-2010, 07:48 AM
  2. Replies: 15
    Last Post: 07-02-2007, 01:49 PM
  3. 1997 lt1 missing at idle and popping from exhaust help please
    By 30thcamaroz28 in forum General Help
    Last Post: 05-09-2007, 11:27 AM
  4. Stock w/ 3400 stall converter VS stock 6 speed?????????
    By greatwhiteZ28 in forum Camaro / SS
    Last Post: 03-04-2007, 01:02 PM
  5. Stall Converter - Help
    By Tonik in forum Automatic Transmission
    Last Post: 04-29-2006, 12:04 AM
