Thread: Best way to remove transmission
11-10-2008, 05:44 PM #1
Hello, What is the best way to get at the top bellhousing bolt on an A4 trany?
Should I just drop the back of the trans down?
11-10-2008, 06:58 PM #2Royal pain in the....
- Aug 2007
- savannah, ga
2001 Z-28 A4 NBM- 2002 35th anni SS M6#1696
support the trans, remove the crossmember/torque arm
let trans hang off engine to access top trans bolt/harness bracket..ect...ect..
watch that you dont break the oil pressure sender
good time to change oil pressure sender,rear main and back spark plugs with trans out.
11-11-2008, 05:45 AM #3Awaiting Activation
- Aug 2007
- odessa,texas
69 hugger orange- 98 z28
it might be necessary to jack up on the front of the motor a little also
make sure you undo the torque converter from the flywheel,i know its common sense but i have seen people pissed because they couldnt get the tranny out and they hadnt even unbolted the t.c. yet
11-11-2008, 10:14 PM #4
LOL Actually that help because this is my first automatic I will be taking out. Everything else has been manuals.
11-11-2008, 10:46 PM #5
there is a small round (plug) about 11/2-2 inches across on the bottom of the bellhousing just to the driverside. pop that plug out and you can get a large flathead screwdriver in there to turn the motor over with the teeth on the flywheel. take the starter out and turn the motor till you can see the torque converter bolt in the hole where the starter was....there are 3 converter bolts..
good luck man, dropped mine and had it back in start to finish in about 2.5 hours last weekend so its not that bad
How do I remove this?
By TransAm11973 in forum General HelpReplies: 10Last Post: 12-12-2008, 10:01 AM -
How do I remove pcm?
By ls1monarch in forum Computer & TuningReplies: 5Last Post: 04-21-2008, 08:00 AM -
clearance required to remove transmission
By Berger21 in forum Manual TransmissionReplies: 7Last Post: 03-29-2007, 08:13 AM -
Remove old wax.
By timmyvws6 in forum Showcar and DetailingReplies: 27Last Post: 02-11-2006, 06:08 PM
