03-26-2007, 08:10 AM #1Junior Member
- Sep 2005
- Michigan
Onyx Black- 2000 Berger SS #21
clearance required to remove transmission
Any one know how much clearance I need to remove my T56 trans? I have it off the ground but don't want any surprises when I try to remove it. I've got about 14 inches right now.
03-26-2007, 11:02 AM #2Awaiting Activation
- Mar 2006
- LS1 land
how are you getting the car up?? if you have the bellhousing off 14in should be enough.
03-26-2007, 12:58 PM #3Junior Member
- Sep 2005
- Michigan
I drove the front up on ramps and then bolted 4X4 pieces to the ramps so it could not come down. Then I jacked up the back end and put bricks under the tires and put jack stands under the frame (Just in case). this leaves me 14 inches of clearance under the car to drag out the trans when I get it removed. I am hoping this is enough room to work.
03-26-2007, 03:48 PM #4
03-26-2007, 04:12 PM #5Awaiting Activation
- Mar 2006
- LS1 land
03-27-2007, 03:50 AM #6Junior Member
- Sep 2005
- Michigan
I,ll be picking up a creeper today to make it a little easier on my back. I'm getting to old for this.
03-28-2007, 05:02 AM #7Member
- metro Detroit area
You should have enough room comming out. If you don't have some sort of jack for the trans, you may want to think about one on the way back in.It can be a pain aligning the trans properly while holding it up( 120 pounds).
03-29-2007, 08:13 AM #8Junior Member
- Sep 2005
- Michigan
I am not to fond of dropping transmissions on my head so I will be using a jack.
so why are we all required to..
By jiveass in forum Almost Anything GoesReplies: 130Last Post: 06-30-2011, 07:40 PM -
what is required?
By jiveass in forum General HelpReplies: 2Last Post: 01-06-2011, 07:24 PM -
What is required...........
By Y2KPewterSS in forum LS2/LS3/LS4/LSxReplies: 30Last Post: 10-18-2010, 08:38 AM -
Question: Best way to remove transmission
By JaycenK in forum DrivetrainReplies: 4Last Post: 11-11-2008, 10:46 PM -
are new lifters required?
By silverws6 in forum Internal EngineReplies: 3Last Post: 09-07-2005, 04:27 PM
