Results 1 to 13 of 13
    The Rookie
    Guest
    Which Brand Gears?
    I have an m6. I hear a lot about which size, but what brand is the best with the least amount of whine and which is the strongest, best built? I hear Richmond whines quite a bit. What about Motive? What other Name brands are out there?
    This isn't my daily driver, but don't want to hear the whining when I drive it.
    Junior Member alamantia's Avatar
    NJ
    1995 Z28 & 2002 Z28
    GM gears are the softest and quietest, I beleive GM buys them direct from AAM otherwise Motive are fine. And dont buy all that propaganda about breaking them in with jackstands and running the car etc. break them in the same way you did when you bought the car with 0 miles on it, beat the hell out of it.
    Still learning
    Arnold
    2000 SS
    Wondering the same thing
    I have a 2000 ss with M6 and i want to install 4:10. i have seen many people use motive gears. good, bad, other
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    motive are fine. the 4.10 gears whined in my car. i now have 3.73 AAM gears in both cars. really quite.
    Member tici's Avatar
    Zurich - Switzerland
    1998 M6 vert TA
    I just installed a Yukon gear set (3.42 ratio for a series 2 carrier).
    I reused the same pinion shim and I had to adjust the backlash a little bit.
    Pretty easy to install and to adjust and no noisy at all.
    During coast I hear just a little something between 50 and 30 mph, but it could be the snow tires I have now.
    EDIT: it's not the snow tires. It's the rear end!
    MODS: A4 > M6 conversion, SC raptor hood, Vortech V9 G-Trim SQ, homemade water-alcohol injection
    DYNO: 410 RWHP, 417 TORQUE @ 5 PSI
    Heavy Set Thin Guy t/as&dds's Avatar
    MA
    Quicksilver Metallic
    2005 Pontiac GTO
    So is it necessary to get an installation kit to install a set of 4.10s in a 3 series 3.42 M6 car? I have heard that it's a good idea since you're already in there but I haven't been able to find anything regarding the 'paddles'.
    Thanx
    1998 M6 vert TA
    You need at least pinion and carrier shims, marking compound and something to seal the cover (a gasket or RTV).
    The bearings may be OK, but you'll know it only once the rear end is open.
    I personally replaced all the bearings and seals.
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    I would go with the Motives.
    Anyone picked up the new Summit Racing yet? Motive now offers a bullet proof guarantee on their gears. For a ring and pinion as small as a 10 bolts, you can't go wrong with it.
    I put motives in my car and they are nice and quiet. I installed richmonds into my boyfriends formula, they make a little bit of noise...they are supposed to be stronger. But I'd rather have a quiet, motive gear with a bullet proof guarantee.
    When you pick a gearset, call the manufacturer and ask about a paddle kit. Before you call make sure that you have a torsen carrier, because an auburn carrier uses an axle pin and you wouldn't have to change that. I'm not sure exactly which gears you need to use a paddle kit with, my motive 4.10s were fine without it.
    Basically the paddle takes the place of the axle pin in a torsen. When you add a wider gear you can no longer get the paddle back in because the ring gear is too thick. The paddle 'kit' is simply a regular paddle split in half, so that you can insert one, move it over, and insert the other one so it fits fine.
    Do bearings based on mileage. If you have a low-mileage car and it makes no noise, its safe to say you can reuse your stock bearings. If you're getting up there in mileage, then spending $80 on an install kit would definitely be worth your while.
    orlando, fl
    2014 camaro 2ss/rs
    i didn't use a paddle kit with my 4.10 gears. just ground some off the paddle to get it to clear.
    Charlotte, NC
    99 Firebird Formula
    You could do that too but not everyone has access to tools like that. I would've done that also if I needed too, because $160 for a couple pieces of metal is a little outrageous
    ruff ruff rotwiler's Avatar
    WA State
    LT's, 3400 stall, FIPK,CB
    2002 Z28
    I had Yukon 3.42's put in to replace the 2.73's and they whine some, but have held up to lots of abuse at the track. After I broke them in, I went with Royal Purple and they are a little quieter now. I didn't get a lot of whining until I drag raced it and did some hard launches.
    Future Super Trooper Mr. CarelessAndImprudent's Avatar
    Rolla, MO
    '69 Camaro
    I just gota set of Richmonds, but I don't know if they're noisy yet.
    I'm kinda hoping so, because louder is better in my book!
    1998 M6 vert TA
    Quote Originally Posted by rotwiler
    Was it a series 2 carrier + a thick ring? This is what I've done (also Yukon).
    It also whine a little.
    Is Royal Purple synthetic 75W140? I filled something similar and it helps a little, but only until the rear end gets warm. After that the oil becomes more fluid and the whine shows up...
    Is your rear end whining during drive or coast?
  1. what brand gears?
    By 02sunsetorangeZ in forum Manual Transmission
    Last Post: 12-24-2010, 07:25 PM
  2. Brand New In Box 3:73 Gm Motive High Performance Gears.
    By robb4964 in forum Parts For Sale / Trade
    Last Post: 04-09-2009, 04:01 AM
  3. what brand of gears to go with??
    By blue02Z in forum Drivetrain
    Last Post: 11-26-2007, 11:56 AM
  4. What Clutch and What brand of Gears?
    By sfletch2000 in forum Drivetrain
    Last Post: 04-28-2007, 10:32 PM
  5. 3:73 gears, 3:42 gears, clutch, flywheel, plug wires
    By ls1hater in forum Parts For Sale / Trade
    Last Post: 08-16-2005, 06:15 PM
