04-19-2007, 03:10 PM #1Member
- Feb 2007
- Bakersfield, CA
86 Buick Grand National- 02 WS6-M6 407 RWHP
What Clutch and What brand of Gears?
I'm gonna change the clutch out in my t/a soon and want to know which one to go with? My goal is to reach about 425 RWHP which i should be there once i get some new heads. Am i gonna have to change the flywheel to or can i keep the stock one?
Also i'm gonna get some 4.10 gears which brand do you guys recommend?
04-20-2007, 10:38 AM #2Member
- Aug 2006
- Folsom,CA
Black- 2002 Trans am WS6
get the spec stage 3 clutch
04-22-2007, 04:13 PM #3
Mcleod single disc kevlar. Comes with everything you need. Mcleod>Spec.
04-23-2007, 09:17 AM #4Member
- Aug 2006
- Folsom,CA
spec owns all lol
04-26-2007, 11:38 AM #5
I've had really good luck with my Spec stage 3.
04-28-2007, 10:32 PM #6
I would say TEXTRALIA for clutch and GM 4.10s for gears my mechanic installed both in mine and stands by these products. O and since you are in there my advice would be to spend the extra $65ish dollars and change out your slave cylinder, and check out your axles while you are in the rearend. Preventative maintenance will save you lots of dough down the road.
had bad experience with Centerforce and with SPEC 3+.
.02
what brand gears?
By 02sunsetorangeZ in forum Manual TransmissionReplies: 22Last Post: 12-24-2010, 07:25 PM -
Brand New In Box 3:73 Gm Motive High Performance Gears.
By robb4964 in forum Parts For Sale / TradeReplies: 2Last Post: 04-09-2009, 04:01 AM -
what brand of gears to go with??
By blue02Z in forum DrivetrainReplies: 8Last Post: 11-26-2007, 11:56 AM -
Which Brand Gears?
By The Rookie in forum DrivetrainReplies: 12Last Post: 01-27-2006, 01:13 PM -
3:73 gears, 3:42 gears, clutch, flywheel, plug wires
By ls1hater in forum Parts For Sale / TradeReplies: 4Last Post: 08-16-2005, 06:15 PM
