Results 1 to 20 of 23
Thread: what brand gears?
12-23-2010, 10:12 AM #1
what brand gears?
i cant find any threads but im buying 3.73's and were looking at richmond or motive, any suggestions?
12-23-2010, 10:42 AM #2Exalted Cyclops
- Feb 2007
- San Diego, CA
I'd go with AAM. I've had Motive and Richmond but the AAM gears were the only gears I had that didn't whine.
Between Motive and Richmond I'd go with Richmond.
I currently have stocker 3.23's because I burnt up the pinion bearing (and bearing surface - they got friction welded together) on the AAM gears.67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
12-23-2010, 10:52 AM #3
alright thanks! My car has stock 3.42's so do i have a 3 series carrier? also where can you buy them, i cant find any
12-23-2010, 02:45 PM #4Junior Member
- Dec 2010
- Upstate, SC
Black- 1999 camaro
12-23-2010, 02:47 PM #5
Guessing you're an auto?
12-23-2010, 03:22 PM #6Junior Member
- Sep 2007
- Fort Wayne, IN
Red- 2002 Chevy Camaro SS LE
I recently put 3.73 AAM gears in my car after I blew the 4.10's. I bought the GM OEM gear set (made by AAM for GM) from Jaws Gear and Axle for $265 plus shipping. I also paid to have them setup by a professional for $150 because I did not want any gear whine. The prior owner of the car had Motive 4.10's installed and they whined like crazy. The new 3.73's are nice and quite, so I am happy I paid the extra $ over other brands.
Perhaps with proper setup other brands would be quite also, but I did not want to take the chance. I read many posts about the GM OEM gears being the quietest. It may depend on how important quiet gears are to you.
Good Luck02 Camaro SS, 35th Anniversary Limited Edition #1021, 6-speed, T-Tops, 345HP SLP option, CME, 3.73's, J&M LCA's, UMI 3-pt SFC's, Strano springs, KONI SA's, Strano 35mm front sway bar, Hellwig adjustable rear sway bar, Hawk HPS, UMI adjustable PHB
12-23-2010, 03:34 PM #7
12-23-2010, 03:55 PM #8
3.42's were 6 speed gears for all 4th gens exclusively. It's the 3.23's you are thinking of as the optional upgrade automatic gear for the Z's and TA's, and standard on the SS and WS6 autos.
Anywho,,,,I've setup a couple of Motives without complaint, all were quiet, but I don't use them myself. I prefer Richmond over anything else. I've setup so many I couldn't even give a number. I've had goodluck with Richmond being quiet and tough. Any issues I've ever had Richmond always took care of with another gear set if necessary free of charge. Good people to work with.
I've also had goodluck with some Yukon gears for trucks when I deal with Randy's Ring-and-Pinion. With any gear, setup is key.
12-23-2010, 04:21 PM #9
12-23-2010, 04:30 PM #10
12-23-2010, 04:32 PM #11
I've never seen, heard, or even torn one down from an auto that had 3.42's.
GM got out of the gear game after the early 70's when everything became pretty standardized as far as packages go.
Now that doesn't mean GM slipped up and stuck a 6 speed rear in an auto going down the assembly line, since this is all done as sub-assemblies, I've seen stranger things restoring 60's muscle cars,,,,but I find that highly unlikely.
All your 6 speeds have the 3.42's. Nothing else available from GM when new. The auto's have 2.73's, or as an option 3.23's. The auto's in the SS or the WS6 came standard with 3.23's.
12-23-2010, 04:47 PM #12Exalted Cyclops
- Feb 2007
- San Diego, CA
*Heavy sigh*No, they don't...
When are you kids gonna stop believing in fairy tales?
Got any proof that anything gear wise was any other than what FBJ sez above????
I repeat, base Z28 w/A4 = 2.73 with 3.23 optional. SS = 3.23 standard (no options from the factory). M6 = 3.42 (again no options).
I believe this was the same for the Firebird Formula and WS6 but can't say for sure.
Aftermarket and tuner cars are up for grabs...
12-23-2010, 07:36 PM #13Senior Member
- Apr 2008
- Madison, WI
Yes the Pontiac side of that is the same. All M6 Formulas and Trans Am got the 3.42, A4 had the option of 2.73 and 3.23(not 100% sure on model breakdown)
12-23-2010, 07:56 PM #14
12-24-2010, 12:41 AM #15
I have had good luck with my motive gears. I would stay away from Richmond they used to whine in my 5.0 so after that I never got another set but I do know someone who got a set for their Z28 and they were a lot louder than mine.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
12-24-2010, 08:04 AM #16
haha sorry fellas, yeah that was a drunk post and messed up the numbers.
12-24-2010, 10:32 AM #17
12-24-2010, 10:36 AM #18
12-24-2010, 10:40 AM #19
6 speed? I'd just leave the 3.42's then and concentrate on building an engine with low end torque. Because jumping to 3.73's isn't a big leap. With a 2.66 first gear, these cars really need more rear gear to be optimum, and a 4.10 is a start. Gets you in the high 10 numerical overall ratio, which is what you want for acceleration.
With the .50 overdrive it's not even a drivability issue
12-24-2010, 01:07 PM #20
idk i guess its just my preference lol cuz everytime i drive his car it seems like i get worn out almost like its a chore to drive. I mean i know a standard is most of the time but i love driving my car with 3.42's so i figured 3.73's would help some but still feel great, i mean i might do 4.10's later, just trying out different options. Thanks for all the advice!
Brand New In Box 3:73 Gm Motive High Performance Gears.
By robb4964 in forum Parts For Sale / TradeReplies: 2Last Post: 04-09-2009, 04:01 AM -
what brand of gears to go with??
By blue02Z in forum DrivetrainReplies: 8Last Post: 11-26-2007, 11:56 AM -
What Clutch and What brand of Gears?
By sfletch2000 in forum DrivetrainReplies: 5Last Post: 04-28-2007, 10:32 PM -
Which Brand Gears?
By The Rookie in forum DrivetrainReplies: 12Last Post: 01-27-2006, 01:13 PM -
3:73 gears, 3:42 gears, clutch, flywheel, plug wires
By ls1hater in forum Parts For Sale / TradeReplies: 4Last Post: 08-16-2005, 06:15 PM
Those were the days.
