    Member shadowsnkx's Avatar
    Laurel, MS
    Blue
    1998 firebird formula
    removing engine need advice
    I have a 98 formula and have been planning to rebuilt the engine for sometime now. I have removed everything from the inside of the car except the block and the as compressor. I will be pulling the engine from the top with a hoist so I took everything off to make it easier because i'm doing it alone.
    My questions are simple.
    1. I have unbolted the bellhousing at the back of the engine. Do I still need to remove the allen bolts on the flexplate?
    2. Where should I attach the chains for my engine lift? Motor mounts?
    3. Do I need to move the tranny back and add some additional support for it?
    Bragg NC
    Met. Sunset Orange
    01 SS
    Support the tranny with a jack stand, you can pick up a intake plate that bolts to the valley and you can pull from top with it.
    J
    Member TROYWS6X's Avatar
    New York
    1998 WS6
    Pick up the book "How to Build High-Performance Chevy LS1/LS6 V-8's" by Will Handzel. Lots of tips and tricks for removing and installing the engine
    Quote Originally Posted by shadowsnkx View Post
    if i can remember and can get my hands and camera in to the bay i can snap some picts of where you bolt the chains to... but your best bet if you have an available lift is to drop the engine out from the bottom... it is soooo much easier...
    Cedar Rpaids,IA
    1998 Camaro SS
    I'm with Spaz on this one. Its way easier to drop the engine out the bottom. When I did it I dropped the tranny, engine, and K member together and used tranny jacks to lower them slowly, then placed it on an engine cradle. Out the top is possible, but lots of things to dent, scratch, or bust off since the engine sits so far back in the engine bay.
    1998 Camaro SS Hard Coupe Bright Red #1593
    Mods: Lots!!, still my daily driver except for winter
    383rwhp 370rwft/lbs
    1979 Corvette
    Mods Lots!!, weekend cruiser
    325rwhp and 320rwft/lbs
    2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
    Mods: Catback, BFI CAI, Winter daily driver
    Laurel, MS
    Blue
    dropping from the bottom is not an option for me. I just don't have the space to do it. I'm working on my driveway which is a slab, but I live in a city so I have to keep everything clean. I'll be taking it out throught the top this evening.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    if the chain has large enough holes, then use an old head bolt. i used the back of the motor where the trans bolts to it and on the front where the alternator bolts to the block.
    Laurel, MS
    Blue
    got it out last night by using the motor mounts as the lift point. Once I got it loose from the bellhousing dowel pins it was easy.
  1. Engine advice
    By WS6Doc in forum Firebird / WS6
    Last Post: 01-14-2013, 12:48 PM
  2. Removing Engine / Transmission
    By slade8200 in forum General Help
    Last Post: 06-27-2012, 06:52 PM
  3. General, removing components (engine bay)
    By SS Camaro UK in forum General Help
    Last Post: 06-04-2012, 09:46 AM
  4. Advice on removing 10 bolt..
    By One_Bad_TA in forum Drivetrain
    Last Post: 02-06-2009, 01:30 PM
  5. Replies: 0
    Last Post: 09-29-2007, 06:50 AM
