Results 1 to 1 of 1
09-29-2007, 06:50 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Removing The Engine From A C5 Corvette - Removal Procedures Part: 1
If you want to perform engine modifications to your C5 Corvette beyond installing a different airbox or some exhaust system modifications, the engine will need to be removed. But pulling the engine on the C5 is a little different than what most enthusiasts are used to doing. That's because the best way to do it is to lift the body off the engine, torque tube, transmission, and front and rear suspension units that make up the "spine" of the C5 Corvette.
While the idea of doing this to your baby might sound much more daunting than "just" pulling the engine, removing the drivetrain unit is actually quite straightforward once you have seen it happen. Which is where this two-part story comes in: We are going to show you most of the steps required to complete this process.
Where to Start
As always, whenever working on your vehicle, disconnect the battery cables first. this is especially important with this process as it involves removing the Powertrain Control Module (PCM), the alternator, and most of the underhood electrical system. Handling any of these components or systems while powered could be dangerous on many fronts (to you and the components).
The first work to be performed is the removal of the shifter from the center console in the interior of the vehicle. It's a good idea to start with this step before the vehicle goes on the lift as the doors can safely be swung open (versus when the vehicle is on the lift and the lift legs are in the way of opening the doors). Simply put, getting the shifter out first means you won't have to get into the interior for the rest of the engine/drivetrain removal process.
Once the shifter is removed, the vehicle can be put on a two-post lift, and the drivetrain component and system removal process can happen. Many folks ask if a two-post lift is absolutely necessary, but after seeing the photos of how the drivetrain comes out of the vehicle, we doubt there will be too many questions. The factory puts the drivetrain in from under the vehicle, so if you want to do this process right, you'll gain access to a two-post lift and raise the body off the drivetrain to get at the engine.
Take a look at the photos and captions of this first half of the process and look for the rest of the story next month right here in CF.
Photo Gallery: Removing The Engine From A C5 Corvette - Corvette Fever Magazine
More...
Transmission Removal - Part 1
By pajeff02 in forum Automatic TransmissionReplies: 34Last Post: 02-09-2014, 04:47 AM -
Removing Engine / Transmission
By slade8200 in forum General HelpReplies: 8Last Post: 06-27-2012, 06:52 PM -
Corvette Engine Build - The Power Principal, Part
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 12-09-2009, 10:10 AM -
removing engine need advice
By shadowsnkx in forum General HelpReplies: 7Last Post: 10-03-2008, 10:36 AM -
Removing Interior part?
By Bouvers in forum General HelpReplies: 2Last Post: 05-14-2008, 11:49 AM
