    Junior Member kiko415's Avatar
    Sep 2008
    SOUTH SAN FRAN
    white & not painted yet
    2000 Z28 & 1984 Z28
    Exclamation Motor wants to over heat & oil pressure drops?
    ok i have a question
    i have a 98 camaro Z28 and when i am driving it in hot weather, lately my temperture gauge has been going up and i have changed the hoses and thermostat, and when the temperture goes up the oil pressure drops.....does anyone know whats going on.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    How low is the oil pressure dropping?? Its normal for it to drop somewhat when the engine heats up, since the oil thins out with the increased tempuratures and flows much easier through the motor.
    What temperature is the engine getting up to?? Sounds like you may have a cooling fan issue, perhaps a bad cooling fan relay or coolant temp sensor.
    Sep 2008
    SOUTH SAN FRAN
    2000 Z28 & 1984 Z28
    the oil preesure drop to almost nothing, and the temp almost maxes out
    USA
    Velocity Yellow
    2008 Corvette Z06
    How is the oil level? Do you notice any leaks anywhere? Hopefully you don't have a head gasket issue!
    2018 Tahoe - Silver - OEM
    Member CompSyn's Avatar
    Pacific NW USA
    Post Cooling issue
    Quote Originally Posted by Wesman View Post
    Motor oil thins out as it heats up. Find out the cause of your cooling issue. Then your oil pressure issue will be corrected as well.
    CompSyn
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by CompSyn View Post
    CompSyn
    It definitely shouldnt go down to 0 though.... there is something else going on.
    Feb 2006
    2002 WS6
    Start with your fan operation and get a coolant flush done. Also under what condition exactly does it do this, all the time or on the move?
    Pull off the upper rad cover/airbox and see what kind of crap has gotten sucked in there. If that air space get blocked, or the lower deflector under the car gets broken off it will cause the car to over heat.
    When was the last time you checked the coolant level? They don't like getting too low.
  1. Ls1 oil pressure drops when pressing the throttle
    By VtBandit in forum Internal Engine
    Last Post: 12-05-2010, 07:14 PM
  2. Replies: 4
    Last Post: 12-29-2009, 03:51 AM
  3. *Jaw Drops*
    By ROADRACER247 in forum Almost Anything Goes
    Last Post: 10-21-2008, 10:46 AM
  4. Replies: 20
    Last Post: 02-15-2007, 08:28 AM
  5. ac/heat blower motor making noise
    By sg5492 in forum General Help
    Last Post: 02-12-2006, 04:25 PM
