    Janesville IA
    2003 Corvette
    fuel pressure drops with key on and motor not run
    I have a 95 Z28 that is sometimes slow to start. I checked the fuel pressure with the key on and the motor not running. It runs up to 49 pounds while the pump is running. As soon as the pump stops it drops to about 10 pounds. Is there a check valve or something that keeps the pressure up while the pump is not running? I am using a Haynes maunual that says the pressure should hold steady.
    Thanks,
    Bruce
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    How is the pressure when it is running? Are you checking it with the vacuum line disconnected from the regulator? Sounds like it is leaking down though. Could be an injector or the regulator.
    Janesville IA
    2003 Corvette
    The pressure is 41-43 with the motor running. I did not disconnect the vacumn line from the regulator.
    Jan 2008
    Athens AL
    Navy Blue
    1998 Formula Firebird
    Quote Originally Posted by retriever View Post
    Thanks,
    Bruce
    Yes there is a check valve and the pressure should hold for a very long time. It is fairly common for them to go bad and hey can be a pain in the ass to change, i know several people who have just cut a door in the rear deck, because dropping the tank is fairly time consuming. if its dropping really fast, (<10 sec) and has no drivebility problems its most likely the pump.
    Janesville IA
    2003 Corvette
    Thank you, I will get back to working on it in the next few days.
  1. Ls1 oil pressure drops when pressing the throttle
    By VtBandit in forum Internal Engine
    Last Post: 12-05-2010, 07:14 PM
  2. Question: Motor wants to over heat & oil pressure drops?
    By kiko415 in forum General Help
    Last Post: 09-11-2008, 10:28 AM
  3. Replies: 20
    Last Post: 02-15-2007, 08:28 AM
  4. Replies: 3
    Last Post: 04-01-2006, 03:59 PM
  5. Looking for gauges! nitrous pressure, fuel pressure!
    By texasss in forum Parts Wanted / Trade
    Last Post: 10-29-2005, 09:05 AM
