11-06-2010, 05:42 AM #1
Ls1 oil pressure drops when pressing the throttle
Hi, I have a 98 ws6, no mods done that i have noticed recently has the oil pressure drop when i accelerate after being warmed up. It does it while driving or sitting at idle. It used to increase when i throttled it, just started doing this about a month ago. Checked oil, it is full. Only other thing i noticed preceding this happening was a few months ago it started ticking slightly at startup. Like a sticky lifter in my old 305...Just slight and it goes away when warm. Other than that i noticed nothing different. Any thoughts on why this is occuring? Should i be concerned something is gonna go bad? Anything i can do to stave it off if it is a sign of bad to come?
Thanks
F Small
Oh yeah, has good oil pressure otherwise, just drops slightly when throttling it slow or fast doesn't matter...Last edited by VtBandit; 11-06-2010 at 05:45 AM.
11-10-2010, 08:05 AM #2Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
Typical sign of large bearing clearances. Initial drop because tolerances open up on acceleration then rises as oil pump speed increases with rpm....
12-05-2010, 05:19 PM #3Junior Member
- Nov 2010
- west chester ohio
Metallic Blue- 2002 trans am ws6
i have seen pressure drop due to a split in the o-ring that goes between the oil pump and pick up tube
12-05-2010, 06:51 PM #4
i notice I usually have to add half a court of oil when I see this happen. I will sometimes notice that my oil pressure will drop on acceleration because of lower oil levels. My Z28 did this as well as my SS does.
12-05-2010, 07:14 PM #5Senior Member
- Nov 2009
- NOVA
2002 C5 - M6 - Blue- 2000 Z28 - A4 - Pewter
My white one does this. When it's warm, at 2k RPMs cruisinig around 65mph on the highway, it'll sit at 40lbs maybe less. I can get off onto a main county road, and when on my initial deceleration, the pressure jumps up about 5-8lbs for a few seconds then goes back down. Oil is at the tip top of operating range as well
Motor won't be ready till spring, don't wanna replace as of yet
fuel pressure drops with key on and motor not run
By retriever in forum LT1Replies: 4Last Post: 12-29-2009, 03:51 AM -
*Jaw Drops*
By ROADRACER247 in forum Almost Anything GoesReplies: 44Last Post: 10-21-2008, 10:46 AM -
Question: Motor wants to over heat & oil pressure drops?
By kiko415 in forum General HelpReplies: 6Last Post: 09-11-2008, 10:28 AM -
Check guage comes on after warm up at idle and oil pressure drops to 0
By dafaic in forum LT1Replies: 20Last Post: 02-15-2007, 08:28 AM -
Unemployment drops to 4.7%
By Element187 in forum Political / Debate ForumReplies: 2Last Post: 02-03-2006, 09:28 AM
