Results 1 to 19 of 19
    Kenosha WI
    Rally Red
    98 Camaro SS Convertible
    Angry Where can one buy a brake caliper mounting bracket
    I have an absolutely frozen caliper guide pin stuck in the mounting bracket, I almost dead lifted my car just trying to loosen it up. Where can I order one for my front right brake? I have found tons of rear caliper mounting brackets, where are the fronts??? Thanks in advance to anyone who can help.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    PM me & I'll give you a link.....less than $30 each.....genuine GM
    Member txz28's Avatar
    sheldon, TEXAS
    dirty aka white
    2000 Z
    Quote Originally Posted by SS98 View Post
    get a "rose" bud torch and heat up the metal around the guide pin and while your doing that put a pair of vicecrips on the pin and pull/twist. may take some time it took my father and i like an hour to get mine freed up damn mbrake plus didnt grease them. last time i paid to get them done.
    Kenosha WI
    Rally Red
    Txz28,
    Did that this morning, took a while and started to stink like hell, but it worked, thanks for the info.
    Rbob,
    that is the most evil looking dog I have ever seen, good use of red eye.
    sheldon, TEXAS
    dirty aka white
    2000 Z
    now be for you reinstall it inspect the pins and be sure to apply heavy hi temp grease to them when you put them back
    Junior Member Mentu's Avatar
    Monterey CA
    1999 Z28
    what is the link to that site. I had the same problem then broke the pin off.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Quote Originally Posted by Mentu View Post
    Im with this guy...
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Im with this guy...
    www.rockauto.com
    Some of the best prices I've seen.....
    Beaver Dam KY
    79 T/A -91 Firebird
    Quote Originally Posted by rbob93 View Post
    www.rockauto.com
    They are only for the rear though which you can buy at any local parts store for the same price
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Well dammit!
    Guess I should have looked closer.....My bad
    Beaver Dam KY
    79 T/A -91 Firebird
    Well dammit!
    Who wants to start making these lol?
    Member Piranhaz's Avatar
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Just searched this and this must be common. Check this out though, the P.O. must have broke the pin off so they welded it back on!!!! These things need to be able to slide.
    Only reason I found it was because I was taken them apart to clean some crappy paint that someone had put on the calipers and I found it. Plus one of the bolts on the driver side is froze up as well :-(. Started searching E-bay and I found some (used), but who's to know they aren't the same as what I already have???
    Has anyone found these new anywhere yet??
    Ugh................
    lmpounded SandmanWs7's Avatar
    Dallas, Texas
    2007 CTS-V
    www.rockauto.com
    That is who I use ALL the time when I need something.
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Quote Originally Posted by SandmanWs7 View Post
    They have a lot of parts, but as stated above, they do not carry the front bracket
    Just a farmboy V8MUSCLE's Avatar
    Montpelier, VA
    2000 Pontiac Trans Am
    napa or advanced auto, they can usually get stuff like that.
    Aug 2008
    Minnesota
    1999 Trans Am M6
    For those that need to know, you can get this bracket from Napa, but it comes with new calipers as well, for $60. Maybe not a bad price, but I still hate spending that on extra parts I don't need :-(
    Brakes = stopping (kind of important) LOL
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by Piranhaz View Post
    We do'nt need no stinking brakes!
    Sep 2009
    texas
    maroon
    2000 trans am
    fparts.com should have them.
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Quote Originally Posted by z06bigbird View Post
    Yeah, I checked there too. Only problem with buying used is you could get exactly what you already have :-(
  1. brake caliper bracket question
    By mrpontiac80 in forum General Help
    Last Post: 06-08-2011, 05:50 PM
  2. torque arm mounting bracket
    By bpopham22 in forum Suspension and Handling
    Last Post: 01-28-2011, 06:29 AM
  3. 98-02 Camaro-Firebird Brake Caliper bracket!!!!
    By 9t8z28 in forum Parts Wanted / Trade
    Last Post: 07-13-2008, 03:22 PM
  4. brake caliper bracket.. anyone got one? pass side
    By eddielb in forum Western Members
    Last Post: 06-22-2008, 11:39 PM
  5. Need torque spec for brake caliper bracket
    By dwhitez28ss in forum General Help
    Last Post: 06-19-2007, 09:30 PM
