Results 1 to 10 of 10
    The red dragon bpopham22's Avatar
    Feb 2010
    San antonio Tx
    2001 pontiac WS6
    torque arm mounting bracket
    When ordering a full length torque ARM do u need to order the replacement bracket or is the one on the rear end still useable? I ordered the longer bolts, its the umi full length adj. Chrome moly one.
    the one on the back of the tranny is still good to use however mostly everyone here will recommend doing the relocate bracket because the cone on the tranny is a weak spot and has been know to break. If you got the $$ go for the relocate.
    Also you can pm the UMI rep on here and he will answer any questions.
    Feb 2010
    San antonio Tx
    2001 pontiac WS6
    U mean the tunnel mount relocation bracket? I already ordered the full length,its for a street car.
    Not the tunnel mount. There is a bracket that allows the use of either a stock or aftermarket full length torque arm that moves the mount off the transmission and onto the crossmember.
    Marylandistan
    2001 Trans Am (sold)
    Not me. Had one, hated it.
    Feb 2010
    San antonio Tx
    2001 pontiac WS6
    Y did u hate it? Too much noise? I want the feel of stock with a lil more bite,so I think ill leave it mounted in the factory spot.
    Marylandistan
    Noise and felt like the car was falling apart.
    Feb 2010
    San antonio Tx
    2001 pontiac WS6
    hmmm yea I dnt want that,I want it to feel stock.
    Pa
    Quote Originally Posted by bpopham22 View Post
    Hello,
    Our full length torque arm will mount to the vehicle with no other brackets needed. It is also supplied with a new bushing that replaces the factory bushing.
    If I can help anymore please ask. Thank you!
    Ryan
    you reuse your stock bracket and just drill the rivets out on the bushing. New torque arm will come with poly bushings...everything is supplied.
  1. Sunvisor mounting bracket part #
    By black crowe in forum Firebird / WS6
    Last Post: 07-02-2011, 06:26 AM
  2. Question: Front sway bar mounting bracket
    By kool-aide in forum Suspension and Handling
    Last Post: 02-07-2010, 07:15 AM
  3. Help: Where can one buy a brake caliper mounting bracket
    By SS98 in forum General Help
    Last Post: 09-22-2009, 04:47 AM
  4. PROCHARGER pulleys mounting bracket
    By LUGNUTT in forum Parts For Sale / Trade
    Last Post: 06-26-2007, 05:52 AM
  5. bottle mounting bracket
    By ls1marine in forum Western Members
    Last Post: 09-17-2006, 12:40 AM
