Thread: Front sway bar mounting bracket
02-05-2010, 04:54 PM #1Senior Member
- Dec 2006
- Deltona, FL
Sebring Silver Metalic- 2002 Camaro Z28
Does the 30mm stock front sway bar use the same size mounting bracket as the 1LE/WS6 32mm front sway bar?
I know the bushing will be a different size, 30mm vs. 32mm. I wasn't sure if the bracket that mounts the sway bar to the front is a different size.
thanks
kool-aide
02-05-2010, 05:09 PM #2
My guess is that the brackets are identical. If no one else posts up, I would be more than happy to get you a measurement.
02-05-2010, 05:11 PM #3
02-06-2010, 04:49 AM #4Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
I used my stock 30mm brackets with my 35mm Strano swaybar so you should be good with new bushings to match you 32mm bar.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
02-07-2010, 07:15 AM #5Senior Member
- Dec 2006
- Deltona, FL
Thanks. It sounds like the bushing gets thinner as the bar gets thicker. I know it seemed like a silly question. In my head I said they must be the same. There is only one bolt location. But fabrication is always a part of building up a car, and I thought it was important to know ahead of time.
I wish I had the spare cash for those Strano sway bars. One day, I can always work to save money.
thanks.
Broke my front sway bar bracket!
By Shermanator86 in forum Suspension and HandlingReplies: 1Last Post: 08-31-2012, 10:57 AM -
front sway bar bracket??
By thugtilidie18 in forum Parts Wanted / TradeReplies: 3Last Post: 01-22-2008, 01:26 PM
