    Junior Member dwhitez28ss's Avatar
    Colorado Springs CO
    Light Pewter Metallic
    Need torque spec for brake caliper bracket
    I can't find the torque specification for the two bolts which secures the front brake caliper bracket to the steering knuckle on a 2002 Camaro. I don't see it in my shop manual.
    Also, should a thread locker e.g. locktite be used to secure the caliper to the knuckle? I don't want it coming loose, but if I do use red or blue loctite can I get the bracket loose to change the pads later? Thanks guys.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    74 ft pounds according to the info in the Sticky at the top of this section.
    Blue Locktite is the removable one.
    Colorado Springs CO
    Got it..thanks. I used RED loctite to hold it all together.
    I personally use the blue on it. Wait until you have to take them back off and you'll see why
  1. brake caliper bracket question
    By mrpontiac80 in forum General Help
    Last Post: 06-08-2011, 04:50 PM
  2. Help: Where can one buy a brake caliper mounting bracket
    By SS98 in forum General Help
    Last Post: 09-22-2009, 04:47 AM
  3. 98-02 Camaro-Firebird Brake Caliper bracket!!!!
    By 9t8z28 in forum Parts Wanted / Trade
    Last Post: 07-13-2008, 02:22 PM
  4. brake caliper bracket.. anyone got one? pass side
    By eddielb in forum Western Members
    Last Post: 06-22-2008, 10:39 PM
  5. Caliper Bracket Bolt
    By TheKitchenSink in forum General Help
    Last Post: 01-13-2007, 11:47 AM
