Results 1 to 16 of 16
Thread: Caliper Bracket Bolt
01-06-2007, 05:10 PM #1KWK N NUF
- Mar 2006
- Arlington Heights, Illinois
NBM- 2001 Trans Am WS6
Lost one of mine, and can't find where to find another one. Not the bolts that hold the caliper itself on. But the bolts that hold the mounting bracket itself on to the car.
01-06-2007, 05:14 PM #2Slow'er'Ass
- Thornton, CO
GM.
Or you can take the other bolt to a Home Depot or something.
Personally...I would go GM for that kinda bolt.
01-06-2007, 08:09 PM #3
I had to buy one last summer from a dealership. I don't remember the price but it was cheap.....well, by dealership standards.
01-07-2007, 12:03 AM #4
i got real lucky when mine fell off while i was stopping at a stop sign it was in the same spot the next day unharmed! i was dreading finding another one on a sunday
01-07-2007, 06:04 AM #5
I'm thinking matching the other one with a grade 8 bolt should work.
01-07-2007, 08:59 PM #6Member
- Burlington, NC
Black- 2000 Camaro SS
Like Mr. Luos said. Go to your local GM Dealership Parts Department and get the proper bolt. The proper bolt is made to withstand the stress on the brakes. It will make a much safer package for you and those that may be around you.
01-08-2007, 02:17 AM #7Member
- Oct 2006
- Oklahoma City
00 LS1, WS6, V8 Gremlin- 96 & 98 GTPs, 64 'Cuda
The bolt is an M12 x 1.75 x I forget how long, it is also Grade 12.9
Not something you're going to easily find but a specialty hardware store may have one even though they'll probably want as much or more than a dealer would.
01-12-2007, 02:22 PM #8KWK N NUF
- Mar 2006
Does anyone know a part number or something on it? Ive talked to Pontiac..and they seem to think there are 4 bolts that hold the bracket on...I didn't think it would be this hard. They are supposed to be sending me a schematic, but im yet to see it come out the fax machine.
01-12-2007, 04:31 PM #9Member
- Oct 2006
- Oklahoma City
No, there's only two large bolts that hold the caliper bracket to the steering knuckle, there are also two smaller bolts that hold the caliper pins on and those are easy to find.
Seriously, call around and find some place that has M12 x 1.75 bolts in Grade 12.9 . Take one of the ones you have left and measure how long it is, if I recall about 2-1/2" which would be around 60 mm. The bolt can be longer but not shorter than what's on there.
I think I know where I might be able to find the GM part # but it'll take a bit of time.
01-12-2007, 04:35 PM #10Member
- Oct 2006
- Oklahoma City
Here's something you'll want:
F-body stock components:
Front and Rear Brakes:
Bleeder Valve 12 N•m 106 lb in
Brake Caliper Mounting Bracket Bolt 100 N•m 74 lb ft
Brake Hose Bolt 40 N•m 30 lb ft
Caliper Guide Pin Bolt 31 N•m 23 lb ft
Wheel Nut 140 N•m 100 lb ft
01-12-2007, 04:41 PM #11Slow'er'Ass
- Thornton, CO
18020035
Maybe??
01-12-2007, 04:44 PM #12Member
- Oct 2006
- Oklahoma City
Still digging, here's how to rebuild your calipers:
http://www.installuniversity.com/ins...er_rebuild.htm
01-12-2007, 04:47 PM #13Member
- Oct 2006
- Oklahoma City
Thought for sure the part # would be in here somewhere but it isn't. My company was involved in coming up with this upgrade:
http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
Somewhere over in that forum is a writeup for the "sleeve method" that does include the part # of the caliper bolt you're looking for, I just can't find it.
01-12-2007, 05:09 PM #14Slow'er'Ass
- Thornton, CO
BOLT FRT BRK CLPA (M11X1.5X64) (W/SLeeve)
98-02 F (J65) 18020035 (Might be 18020036)
BOLT FRTBRK CLPA
18023646
EDIT: Make sure you double check those just in case.
01-12-2007, 09:48 PM #15Member
- Oct 2006
- Oklahoma City
I've rethreaded a ton of those 98-02 LS1 calipers, M12 x 1.75 I'm almost positive about. M11 x 1.5 may be for the V6 models?
If a dealer is too hard to find most salvage yards have an LS1 sitting around and surely wouldn't want but $1 for one of the proper bolts. I know these guys would be glad to be of help, they've got tons of them:
http://www.americancamaro.com/
01-13-2007, 11:47 AM #16KWK N NUF
- Mar 2006
Alright guys, I found some after calling like 6 dealerships. Thanks for the help, its gonna be nice to have her back on the road.
brake caliper bracket question
By mrpontiac80 in forum General HelpReplies: 13Last Post: 06-08-2011, 04:50 PM -
Help: Where can one buy a brake caliper mounting bracket
By SS98 in forum General HelpReplies: 18Last Post: 09-22-2009, 04:47 AM -
brake caliper bracket.. anyone got one? pass side
By eddielb in forum Western MembersReplies: 4Last Post: 06-22-2008, 10:39 PM -
Need torque spec for brake caliper bracket
By dwhitez28ss in forum General HelpReplies: 3Last Post: 06-19-2007, 08:30 PM
