Results 1 to 11 of 11
09-03-2008, 02:45 AM #1Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
Alarm going off when locked with remote.
Can someone tell what is going on with my alarm, if I lock the car with the remote or use the power lock botton in the car the alarm goes off,but if I do it manually it don't.What's up with this? Also I posted about the airbag light staying on but got no good reply,can someone help me with these two issues.I Have had the car 9yrs and these are the frist problems I have ever had.
09-03-2008, 04:08 AM #2
my alarm goes off constantly as well. i haven't gotten around to it yet but someone mentioned that i should turn the sensitivity down on the exterior sensor. i think it's located in the spare tire well.
09-03-2008, 04:37 AM #3Senior Member
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
id try a new battery in the remote and reset the alarm by hold both the lock and unlock buttons down for like 10 secs (theres a certian amount of time but i cant remember what it is). . . the air back light is problably just a bad connection or ground.
09-03-2008, 04:54 AM #4
09-03-2008, 05:27 AM #5
09-03-2008, 10:36 AM #6Senior Member
- Jul 2005
- Jacksonville, FL
Using the remote or power door lock button arms the alarm, locking it manually doesn't. If the problem is the alarm is going off for no apparent reason just after arming that's usually an indication the shock sensor is bad. Easiest way to check if that's the problem is to temporarily disconnect it and see if it stops. I'll thumb through my helms and see what it says about the air bag light staying on....
09-03-2008, 11:34 AM #7Senior Member
- Jul 2005
- Jacksonville, FL
After looking through helms I'd bring the car to a dealership and have them figure out what's going on for the air bag light. There are 10 different "B" codes for SIR alone, each with separate diagnostic procedures - and not following them correctly could result in air bag deployment. Some ask if the carpet got wet or something got spilled onto the SDM (infamous black box)under the console. Only thing I'd try myself would be to reset the PCM and see if it goes away, probably won't though.
09-03-2008, 12:59 PM #8
09-03-2008, 01:44 PM #9Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
09-03-2008, 02:02 PM #10Senior Member
- Jul 2005
- Jacksonville, FL
The shock sensor is on the passenger side wheel well, where the spare tire is. Just disconnect it for a couple days and arm your alarm like you always do, if it stops going off you've isolated the problem. You can also take it apart and see if there's any corrosion in it from water getting in there. The rest of the alarm system should still be operative.
09-03-2008, 02:14 PM #11Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
I tried the post given by Gullett17 and it seemed to work for now.I hope that I have it solved,now on to the airbag light. Thanks to all for their post on both of my problems.The alarm post saved me a lot of worry, because I wanted it to work like it was surpose to .Once again thanks for all the help.I also need to mention that there have been alot of flooding here due to the strom that passed through New orleans.And that also my have been my problem water. either way I got it solved,thanks again.
Street Fighter
Ecu locked
By Dzel in forum Computer & TuningReplies: 20Last Post: 03-27-2014, 06:26 AM -
Can REMOTE START ALARM work on 98 SS M6?
By khickenwang in forum Stereo and ElectronicsReplies: 13Last Post: 03-15-2010, 11:01 AM -
Locked out!
By VtBandit in forum General HelpReplies: 4Last Post: 08-10-2009, 04:43 PM -
locked out
By looty000 in forum Request and FeedbackReplies: 1Last Post: 02-28-2006, 04:02 AM -
Factory alarm remote question
By LS1 pwrd NOVA in forum Stereo and ElectronicsReplies: 2Last Post: 11-05-2005, 06:53 AM
