Results 1 to 14 of 14
02-22-2010, 10:59 PM #1
Can REMOTE START ALARM work on 98 SS M6?
Just wondering about this, want to buy a remote start alarm for my 98 ss m6? With this work? Does anyone have one on a m6 and how is it working?thanks
02-22-2010, 11:07 PM #2
it will work, anyone who can install them knows what to do. i think u haveto bypass the clucth, jus remember not to leave it in 1st gear or it make take off on u
02-23-2010, 01:15 AM #3Junior Member
- Jan 2010
- CHESAPEAKE, VA
ARCTIC WHITE- 2002 35TH ANNIVERSARY Z28
Ive done it several times before. Like el toro loco said you just have to bypass the switch. Just have it installed like any other car and bypass it when you get home. It will definetly move if its in gear though.
02-23-2010, 02:22 PM #4
02-23-2010, 08:51 PM #5Member
- Tulsa,OK
Quick Silver- 2002 Z06
Yeah it will work like said above. The problem is you forgetting to leave it out of gear. Lots of bad things can happen like the car running into a garage door or another car and anyone who did the install could be found liable.
02-23-2010, 08:55 PM #6
^or running thru the garage wall
02-23-2010, 08:58 PM #7
02-23-2010, 09:03 PM #8
Well if you start the engine while the car is sitting in gear it is going to move because the transmission is engaged. In an auto the car would be in park, so it won't go anywhere.
EDIT: Just leave the transmission disengaged (neutral) and pull your e-brake. Just know that if you are going to remote start the car you DO NOT want it left in gear.
I didn't even know it was possible to install one of these on a manual, but I guess I never thought about making it work. I don't drive my Camaro when it's cold, but if I get a manual DD I will be doing this...
02-23-2010, 09:26 PM #9
ok Im planning on gettin one. What should I tell the installer to do?
02-23-2010, 09:40 PM #10
if they do it regularly they should know how, jus tell him its manual. if he a good one an cares about his reputation. he might try to talk u out of it for the safety reason of leaving it in gear, but most guys i talk to who install alarms know how to do it.
02-24-2010, 10:52 PM #11
should I just leave my stock alarm on then? Is it effective?
02-28-2010, 07:27 PM #12
i never leave my car in gear anyone no were i can get it done around tulsa oklahoma?
03-01-2010, 06:19 AM #13Member
- Tulsa,OK
Here in Tulsa I do not think any reputable shop will do it for fear of law suit.. Also all the remote start alarms make it very clear in their instructions that you are NOT to hook up the remote start feature on a manual car. They will install the alarm for you but you will have to hook up the remote start..
I'm sure you can find some small shop that is willing to do it though.
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
03-15-2010, 11:01 AM #14
i already bypassed my clutch when you start it its simple an very easy an i can still hook it right back up if i want
remote start
By supercampeones4 in forum Stereo and ElectronicsReplies: 8Last Post: 03-30-2009, 05:10 PM -
Alarm going off when locked with remote.
By Street Fighter in forum General HelpReplies: 10Last Post: 09-03-2008, 02:14 PM -
Remote Start for 05-06 GTO???
By izm in forum GTOReplies: 3Last Post: 12-02-2006, 03:43 AM -
Factory alarm remote question
By LS1 pwrd NOVA in forum Stereo and ElectronicsReplies: 2Last Post: 11-05-2005, 06:53 AM -
C.S.I is offering Remote Start fall/winter specials. (also custom Stereo Work)
By Sky042 in forum Eastern MembersReplies: 5Last Post: 10-09-2005, 12:32 AM
