Results 1 to 20 of 21
Thread: Ecu locked
03-20-2014, 12:48 PM #1
Ecu locked
So the previous tuner out of Sho Mo Speed locked my ECU. So basically my ECU is a brick. What are my choices other than buying a new ECU?
03-20-2014, 01:11 PM #2Spaz is My Mentor
I know Frost sells them, depending on what was used for tuning he may be able to unlock it.
03-20-2014, 01:17 PM #3
03-20-2014, 01:17 PM #4Spaz is My Mentor
I believe he can unlock it then.
Call him, he's a member & a sponsor.
TunebyFrost.com
03-20-2014, 04:07 PM #5
I agree -- see what Steve (Frost) has to say about it. He does excellent work, is reasonably priced and has a fast turn around time.
03-20-2014, 04:32 PM #6
Email sent just have to wait for his response. If anything I'll replace the whole ECU and retune
03-21-2014, 02:08 AM #7
Let Steve know you're an LS1.com member, please.
03-21-2014, 02:50 AM #8
I mentioned it but I'll be sure to do that when he responds
03-21-2014, 02:57 AM #9
Thank you. Let us know what the answer is to the locked PCM issue.
03-21-2014, 03:18 AM #10
You might want to try PM'ing him on here instead. He probably gets over 100 emails a day.
03-21-2014, 12:18 PM #11
His pm is full.
03-22-2014, 05:14 AM #12
Steve does keep pretty busy -- that's the price of having an excellent reputation and doing great work.
03-22-2014, 05:45 AM #13
Yes sir, unfortunately I can't wait so I'm replacing the ECU and getting my own tune
03-22-2014, 06:57 AM #14
I would have just picked up the phone and called him if I needed an answer right away.
03-22-2014, 07:38 AM #15Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
Yeah hes said that several times. Calling is faster especially when spring time is starting. Spring summer is his busy time. Everyone getting cars ready after being put away.
03-22-2014, 07:39 AM #16
I would of but I couldn't find a number. Either way I think my choices are pretty limited.
03-26-2014, 07:25 AM #17
So I got the tune done. It seems that the ECU wasn't locked in the first place. I have know idea why he said he locked it. But money saved.
We used the previous tune as a base. Very good tune just had to make some adjustments on timing. Very drivable car.
We are going to go more "aggressive" here in the future.
Also the boost gauge reads 17 psi. But in fact I'm only running 11 psi. I'll believe datalog over a gauge any day
03-26-2014, 08:23 AM #18
How was the boost logged -- standalone instrument at the shop? On aftermarket gauges that have an analog output you can create a custom PID with the tuning software so the gauge readout goes directly into the program.
03-26-2014, 09:25 AM #19
Boost was read off of HP software. Gauge is digital
03-27-2014, 03:37 AM #20
Using the MAP sensor then. Got it.
locked pcm
By Cutlass in forum Computer & TuningReplies: 12Last Post: 01-22-2010, 10:42 AM -
Locked out!
By VtBandit in forum General HelpReplies: 4Last Post: 08-10-2009, 04:43 PM -
Locked out!!!
By 01ws6er in forum Request and FeedbackReplies: 2Last Post: 03-22-2009, 11:30 AM -
locked out
By looty000 in forum Request and FeedbackReplies: 1Last Post: 02-28-2006, 04:02 AM -
Im locked out
By gcwillia in forum Request and FeedbackReplies: 1Last Post: 10-23-2005, 08:13 AM
