Results 1 to 11 of 11
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    Firebird won't start
    So my buddy has a 99 bird with a 3.8 A4, after market alarm.
    Lately it hasnt wanted to start, no response at all when he turns the key, he tries it a few times then it goes.
    But a few days ago it quit, theres no response from the key at all. if he puts it in the "on" position his dash lights up, gauges come on, all that stuff. but when he turns to crank, its like nothing happening, no attempts to turn over, no solenoid click. Hes had the starter, battery, and alternator tested, all fine. Its not throwing any ODBII codes either.
    My guess is that the factory anti theft is pissed off for some reason and is locking him out.
    any ideas?
    1999 Trans Am A4
    stupid question, but does the aftermarket alarm have a false start?
    2000 SS Black M6
    I have no idea, I dont think he knows much about the alarm, the previous owner installed it.
    Youre in Paris, were in Tyler, not too far away, like 100 miles
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Clean the key with alcohol and run it in a few times. Leave the car locked for a few hours then try it again.. then move this to the firebird section(mod..)
    Mine has done this before
    Junior Member Intimidator02SS's Avatar
    Aug 2006
    Georgia
    2002 Camaro SS
    Your problem could also be with the ignition switch.
    Junior Member lloydb3's Avatar
    Aug 2008
    Philly
    2002 Camaro Z28
    Is the security light on? I had this happen to my car. Disconnected the battery for five minutes and the car started right up.
    Stang Killer TransAmFanatic's Avatar
    Feb 2008
    Harvey, La
    1999 Trans Am
    check out the chip on the key, and also look at the ignition, the key hold might be worn out, and not letting the chip make contact.
    2000 SS Black M6
    that could be it. Im thinking its a problem with the ignition itself, we tried his regular key, and the spare, neither work. they both seem to be in good condition
    Feb 2006
    2002 WS6
    Disconnect the aftermarket alarm and start there. Aldo check/replace the starter relay if you haven't already done so.
    2000 SS Black M6
    Hes disconnected the alarm, i told him to unplug the battery overnight to reset the factory anti-theft...thatll work right?
    Feb 2006
    2002 WS6
    It may, its a good start.
  1. 02 Firebird Dead/Won't start
    By Shamrox in forum General Help
    Last Post: 02-15-2009, 09:29 AM
  2. 2000 Firebird v6 won't start -- Please help!!
    By jpinto in forum General Help
    Last Post: 11-17-2008, 09:02 PM
  3. Cold Start/Warm Start Problem
    By I'mLS1John in forum General Help
    Last Post: 02-23-2007, 08:11 PM
  4. Cold Start/Warm Start Problem
    By I'mLS1John in forum New Member Introductions
    Last Post: 02-22-2007, 06:26 PM
  5. Firebird will not start - HELP
    By Scotts SS in forum Firebird / WS6
    Last Post: 05-11-2006, 09:22 AM
