Results 1 to 2 of 2
Thread: Firebird will not start - HELP
05-10-2006, 12:01 PM #1Junior Member
- May 2006
- WV
silver- 2002 Camaro SS SLP
My friend has a 1996 V6 3.4 firebird that will not start with the key. It will start from the starter and runs but then quits. She was told the code is the anti-theft system. She does not know what the code was. One local mechanic said it would cost hundreds to fix and another said he could unhook the anti-theft system and fix the problem. Trying to avoid the Dealers high cost. Has anyone heard of this problem and is there a easy fix? Any help would be great. Thanks.
05-11-2006, 09:22 AM #2Junior Member
- May 2006
- RACINE,WI
red- 2001 RAM AIR TRANSAM
Check your ignition key lock cylinder,you will have to open up the column and there are two white wires that rub on the lock cylinder that will short out on you and will cause your problem!!!!
02 Firebird Dead/Won't start
By Shamrox in forum General HelpReplies: 16Last Post: 02-15-2009, 09:29 AM -
2000 Firebird v6 won't start -- Please help!!
By jpinto in forum General HelpReplies: 26Last Post: 11-17-2008, 09:02 PM -
Firebird won't start
By Spikito in forum General HelpReplies: 10Last Post: 08-28-2008, 11:12 PM -
Cold Start/Warm Start Problem
By I'mLS1John in forum General HelpReplies: 11Last Post: 02-23-2007, 08:11 PM -
By I'mLS1John in forum New Member IntroductionsReplies: 0Last Post: 02-22-2007, 06:26 PM
